| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 16 Junior Member | | Junior Member Joined: Jul 2004 Posts: 16 | Wondering if anyone has installed a fiberglass headline, I'm leaning toward putting one in my 49, but would like to hear from someone who has any pointers or an opinion. | | | | | Joined: Jul 2003 Posts: 38 Apprentice | | Apprentice Joined: Jul 2003 Posts: 38 | I installed a ABS headliner in my 39 and was happy with the results. I would think the fiberglass would be similar to istall. Since it must be trimmed, measuring and fitting is very criticle, cut a little at a time. The process will involve putting it in and out numerous times to get the correct fit. Takes two people, one to hold it up and the other to mark it ect. Most important thing is to check twice cut once.
Jim
| | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I used Roddoors ABS in my '51, covered in tweed. You could paint or cover in your choice of fabric's. Easy install I think I only had to trim at rear to fit, and make holes for sun visors. I also glued insulation to roof. I think you can see here http://community.webshots.com/user/zeker6 Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | What color headliner are most follks using in a 1951? I've gone with the brown version as I had brown (I think) on the doors and the dask gauges appear to be brown. I wonder if there was a standard interior color in 1951? | | | | | Joined: Sep 2005 Posts: 16 Junior Member | | Junior Member Joined: Sep 2005 Posts: 16 | I recently bought a fiberglass precut headliner but I can't install it because it's too stiff. Has anyone ever actually installed one?? | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Bat: Not that far yet but what I have read they say lay it in the direct sun for awhile easier to work with!
popcorn The truth is Out There (I hope that helped) | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I have a Roddoors headliner also, we left it black abs for a year. Little trimming and it fit fine. Have some ultra suede material to put on it now. We have our truck all torn apart and ready for paint. I like the roddoors headliner, but thought it was way over-priced. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | The roddoors products are ABS.
has anybody used the roddoors back ABS cover? I removed the gas tank and have thought about getting the ABS cover to ''don't quote me 'clean up the looks of the cab inside''.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
