3 members (baldeagle, Wayne67vert, 1 invisible), 91 guests, and 7 robots.
Topics128,020
Posts1,055,345
Members48,420
#163608 10/07/2005 9:56 PM
U
Junior Member
Junior Member
U Offline
Wondering if anyone has installed a fiberglass headline, I'm leaning toward putting one in my 49, but would like to hear from someone who has any pointers or an opinion.
#163609 10/12/2005 12:51 AM
Apprentice
Apprentice
I installed a ABS headliner in my 39 and was happy with the results. I would think the fiberglass would be similar to istall. Since it must be trimmed, measuring and fitting is very criticle, cut a little at a time. The process will involve putting it in and out numerous times to get the correct fit. Takes two people, one to hold it up and the other to mark it ect. Most important thing is to check twice cut once.
Jim
#163610 10/13/2005 11:57 AM
Z
Z Offline
I used Roddoors ABS in my '51, covered in tweed. You could paint or cover in your choice of fabric's. Easy install I think I only had to trim at rear to fit, and make holes for sun visors. I also glued insulation to roof. I think you can see here
http://community.webshots.com/user/zeker6
Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#163611 10/23/2005 3:51 AM
V
V Offline
What color headliner are most follks using in a 1951? I've gone with the brown version as I had brown (I think) on the doors and the dask gauges appear to be brown. I wonder if there was a standard interior color in 1951?
#163612 10/27/2005 3:20 PM
Junior Member
Junior Member
I recently bought a fiberglass precut headliner but I can't install it because it's too stiff. Has anyone ever actually installed one??
#163613 10/27/2005 4:00 PM
Bat: Not that far yet but what I have read they say lay it in the direct sun for awhile easier to work with!
popcorn The truth is Out There (I hope that helped)
#163614 11/15/2005 11:53 PM
I have a Roddoors headliner also, we left it black abs for a year. Little trimming and it fit fine. Have some ultra suede material to put on it now. We have our truck all torn apart and ready for paint. I like the roddoors headliner, but thought it was way over-priced.
#163615 12/15/2005 11:49 PM
The roddoors products are ABS.
has anybody used the roddoors back ABS cover?
I removed the gas tank and have thought about getting the ABS cover to ''don't quote me
'clean up the looks of the cab inside''.
Jim & Caroline
Moderated by  ndkid275, Phak1
