7 members (TooMany2count, Wheelie, Stovebolt48, Napco Mark, baldeagle, RaNfLaS, Jeff Ogden), 72 guests, and 7 robots.
Topics128,021
Posts1,055,346
Members48,420
#16354 08/21/2004 4:51 PM
Junior Member
Junior Member
I am changing my 1940 216 with a 235 from a 1956. Are power steering pump brackets made to fit this engine? :confused: The ps is also my new brake booster power.the gen will swap to an alternator,that is easy.I might even think about air cond other than tilt windshield. eek so is 3 accessorys hanging on the front of a 235 a bit too much? Thanks for any help.
#16355 08/21/2004 10:44 PM
You can get a bracket kit from patricks to mount the alt and a a/c compressor,the a/c bracket can be modified for a power steering pump if not being used for a/c. Also later model 235,s had two grove pulley /harmonic balancer,s . old navy 51......
