0 members (),
131
Mod | | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi all, I took out the door glass and vent window to replace the vent window rubber. It came out okay after some tugging and cussing. After replacing the vent window rubber I reinstalled everything. Now the door glass is cocked, it's about a half inch lower in the rear. When I try to crank it up the last inch or so is real hard. Also, when cranking down, the window will free fall over an inch then stops. None of this was happening before I took it out and it worked perfectly. I'm about at my wit's end here trying to figure this thing out. Why would the glass be lower at the back? Have I screwed up the regulator? What the @#$% is going on? Thanks for any help, Don | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I don't know if this is it but check the channel at the base of the window... as I recall there are two "rods" that form an "x" as part of the regulator and they have rollers on the ends... make sure both rollers are properly in the channel at the base of the glass.
When I did the windows on my 56 I recall it being a pain in the butt to keep them in place while I was reinstalling. This may not be our problem but off the top of my head it's worth checking. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If this is an AD truck, you won't have an "x" type mechanism. The only way that the glass could possibly tip like that is either it is out of one of the tracks or one of the tracks is broken. I would guess that you know that the divider bar that is part of the vent assembly bolts on to the door, inside near the bottom. | | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Sorry, I should have said this is a TF (57). I have checked and the rollers are in the track. Everything SEEMS to be in order but obviously somethings wrong somewhere. Please keep sending ideas. Thanks, Don | | | | | Joined: Feb 2003 Posts: 43 Junior Member | | Junior Member Joined: Feb 2003 Posts: 43 | don't really have an answer, but redid mine 59 and the drivers side was like that. Real tight but the passenger side was perfect. On the same subject does anyone have sugestion on good replacement for the felt fuzzies at the base of the window. Replaced mine and the chrome strip is below the bottom of the dooor frame.
rebuild not replace
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Remember when you get your hands in those tight places to squirt some spray grease on the rollers and anything else that moves up/down.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Jim's right... and don't forget a good caoting of anti-seize!
And while you're at it add some soundproofing to the interior of the door! | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | may want too check the thickness of your stock glass too the new glass.
dan-pa
| | | | | Joined: Aug 2005 Posts: 60 Member | | Member Joined: Aug 2005 Posts: 60 | what kind of material do you use for soundproofing Larry?
Nolan | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I used a roll roofing product I bought at a Home Depot. Short money. Comes in a 12" wide roll (if I remember correctly)... one side has an adhesive, just cut strips, peel off the backing, slide it down in place and press it on. Check out Alan Horvath's website for all sorts of tips on soundproofing the doors as well floor and cab. The roofing stuff really works well. | | | | | Joined: Nov 2004 Posts: 10 Junior Member | | Junior Member Joined: Nov 2004 Posts: 10 | This is based on the 63 manual and working with my 66 GMC, but might also be a held with yours. The channels front and back are held in placeby several sheet metal screws on the top and front which anchor the entire wing windoe/front chan assmby and on the rear by AFIK 3 pairs of med sm machine screws. While the front is pretty much self aligning, the ones on the rear should all be left quite loose until you have them ALL in and have checked for straightness by looking down through the window opening with a flashlight. Have you removed the wing window asmby before the window lift or have you wrestled the lift out without removing the wing asmby? If you've been wresteling it's probable that the lift mechanism has gotten bent in the process. Rotsa Ruck
IF YOU DIDN'T TEST IT, IT DOESN'T WORK
| | | | | Joined: Aug 2005 Posts: 60 Member | | Member Joined: Aug 2005 Posts: 60 | Thanks Larry, I'll definitely remember that when I'm working on the cab. | | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Thanks to all for responding to my window problem. The fix was unbelieveably simple after I screwed my head on correctly. It was the lower channel that the roller goes into that was causing the problem. The roller was not fully on the track and it was binding up. Got it on right, lubed everything real well, and it's working great now. Thanks again, Don | | |
