| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | The oil pipe on my oil gauge has been cut. ..it is clean and in good shape. Can I add to the lenth or do I need to get a whole new pipe, if so were?Also are there any after market temperature sending units that will hook up to my gauge? Manfighter16 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the tube for the oil pressure can be replaced w/ materials from auto parts stores - if the temp gauge has a capillary tube, sorta like the oil gauge, the whole thing [gauge/tube/sender] is a unit that would hafta be professionally repaired - if the temp has a wire to a seperate sender [eltrical], that sender can be obtained at the stores as well
Bill | | | | | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | Thanks Red,I will just replace the temp gauge Manfighter16 | | |
