5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#163469 08/23/2005 7:10 PM
Junior Member
Junior Member
The oil pipe on my oil gauge has been cut. ..it is clean and in good shape. Can I add to the lenth or do I need to get a whole new pipe, if so were?Also are there any after market temperature sending units that will hook up to my gauge? Manfighter16
#163470 08/23/2005 7:51 PM
the tube for the oil pressure can be replaced w/ materials from auto parts stores - if the temp gauge has a capillary tube, sorta like the oil gauge, the whole thing [gauge/tube/sender] is a unit that would hafta be professionally repaired - if the temp has a wire to a seperate sender [eltrical], that sender can be obtained at the stores as well
#163471 08/24/2005 2:47 PM
Junior Member
Junior Member
Thanks Red,I will just replace the temp gauge Manfighter16
Moderated by  ndkid275, Phak1
