| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 82 | I want to put a 3 pt. shoulder belt in my '49. How can I install the upper mounting point with out cutting out the interior panel ? I can't find any opening top or bottom to sneak a mount ing plate in. Any ideas ?? Thanks. Bruce
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Bruce, I have enclosed a link with an excellent "how to" on this subject. http://www.speedprint.com/Deves50/ Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | forget what i wrote look at atomarc's link what a great forum this bolter page is ... I'd also recommend http://www.julianos.com/ for the belts. several color choices available. if you can make your own anchor braces they're about $65-70. ea. you can buy two different types, bucket and bench seating models. you could probably make you own anchors as theirs didn't look any more special/ or made to fit an AD /TD . the top anchor is placed after drilling a hole pretty high up and away from the corner glass area. remove the overhead backing cardboard panel and fab up a plate w/ a 7/16'' nut welded to it. seatbelt anchor bolts are usually 7/16''. this will slip down the front side of the corner window (if'n you got one) and behind the door upright. I used a long string so I wouldn't lose it down the inside panel. screw in your belt bolt w/ a dab of 242 locktight and your set. the roll up belt fits neetly inside that angled brace in the pocket of the trucks cab. install an external plate under the cab floor.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | There might be some info in the archives that will help. Try searching for something like "shoulder belt." | | |
