2 members (Jay R, Donf), 71 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
#163329 07/22/2005 5:26 AM
I want to put a 3 pt. shoulder belt in my '49. How can I install the upper mounting point with out cutting out the interior panel ? I can't find any opening top or bottom to sneak a mount ing plate in. Any ideas ??
Thanks.
Bruce
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
#163330 07/22/2005 6:24 PM
Bruce, I have enclosed a link with an excellent "how to" on this subject.
http://www.speedprint.com/Deves50/
Stuart
#163331 07/23/2005 12:35 AM
forget what i wrote look at atomarc's link what a great forum this bolter page is
I'd also recommend http://www.julianos.com/ for the belts. several color choices available. if you can make your own anchor braces they're about $65-70. ea. you can buy two different types, bucket and bench seating models. you could probably make you own anchors as theirs didn't look any more special/ or made to fit an AD /TD . the top anchor is placed after drilling a hole pretty high up and away from the corner glass area. remove the overhead backing cardboard panel and fab up a plate w/ a 7/16'' nut welded to it. seatbelt anchor bolts are usually 7/16''. this will slip down the front side of the corner window (if'n you got one) and behind the door upright. I used a long string so I wouldn't lose it down the inside panel. screw in your belt bolt w/ a dab of 242 locktight and your set. the roll up belt fits neetly inside that angled brace in the pocket of the trucks cab. install an external plate under the cab floor.
Jim & Caroline
#163332 07/28/2005 12:28 AM
There might be some info in the archives that will help. Try searching for something like "shoulder belt."
1954 GMC De Luxe COE
Moderated by  ndkid275, Phak1
