3 members (GIJOE298, Peggy M, 1 invisible),
123
Mod | | | Forums66 Topics128,078 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | I have a rubber floor mat installed in my '56--I believe I got it from Chevy Duty. The truck is a 3-spd. column--not floor shift. Have a major wrinkle (kinda' buckled) where the firewall meets the floor to the right of the accelerator pedal below the foot starter. The rest of the floor looks great. Anybody else have that problem? What to do about it? or should I look to another vendor? | | | | | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | try heating the area up. Use a blowdryer for "safe" use, or a torch for "fast and furious" use.
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I would heat it up and get it sitting right ... then glue that puppy!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I've done 2 of those mats, different suppliers, and they both wrinkled there [where the "bulge" in the firewall is right behind the engine] prolly isn't much choice in those, but seems to me at least one of mine had a GSPP logo on it
Bill | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I know this really good plastic surgeon in Southern Calif
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Thanks for the responses, especially about the plastic surgeon.  I tried the heat. Didn't help. I had even thought about cutting the mat along that curved line and reattaching it with tube repair adhesive but.....might be a worse mess than the wrinkle. | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Interesting post--I just laid a rubber mat in my truck, from Chevy Duty, and it fit perfect. Not a wrinkle at all. Is this the mat that has cutouts for the brake/clutch etc? If you got it from CD and it's not right, CALL THEM. They have been excellent assisting me with various problems that have come up during my restoration. Lots o luck  | | |
