1 members (klhansen),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | My passenger side door on my 56 has a door button with a lock. It presses in and out OK, locks OK but when you push the button in it doesn't release the latch. I have to open the door from the inside.
The driver's side has a blank button. So I've ordered new locks (both doors) from Chevy Duty. Anyone ever change the locks? Anything I should look out for??
Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | easy job if the screws that hold the handle in aren't siezed - just watch out, cuz it's easy to drop those screws down into the door when putting'em back in! Bill | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | thought that was the way it's to work :confused: :confused:
dan-pa
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I put new handles with locks, from Chevy Duty, on my 54 ... they work great!
Check the button action from the inside ... see what the knoby-thing hits (or doesn't hit) when you push the button in. I think you'll get it working with a few minor adjustments.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Installed the new lock cylinders yesterday.... went pretty smooth (except getting to one of the screws... a real pain). I did discover that the doors actually have double locks... that is, if you lock the door from the inside, you can't unlock it with a key from the outside. My pass. side still had troubles... couldn't get it to release latch... turns out it was the inner lock causing the problem so I just cut off the little tab. The end result is that I won't be able to lock the door from the inside but will at least be able to use the new keys.
I'm about two weeks away from truck launch! | | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | I'm having the same problem with my 55' chevy truck not opening all the time. I believe the knoby - thing like horvath calls it is worn so bad on the end as you press the door button there seems to be a lack of travel to unlatch the door from opening? | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Let's see... the door button has this small rod attached to it (maybe 1/8" dia)... the old one was a solid piece the new ones are two pieces sandwiched together. On my 56, the driver's door lock was original (with no outside lock). The passenger side had been replaced. I didn't find the little rod on either door worn that much that it wouldn't push on the tab to release the lock. It'd have to be pretty worn to shave off that much.
BUT what I did find on the passenger side (the door that was giving me trouble not opening fronm the outside) was that the little tab that the little rod pushes against was getting hung up.
I think there are two solutions to the problem... 1) Buy a new inside mechanism 2) Cut off the little tab like I did. The only big downside is that I can't lock the door from the inside now. Need the key on the outside. But at least I can now open and lock her up.
By the way, Option #1.. I think you still end up with a double-lock problem as I described above in prev. post | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | My doors are the same -- if you lock 'em from the inside, you can't UNlock 'em from the outside. That's because the key-locks simply prevent the knob from operating, whereas the inside lock (pushing the door handle) does a completely different deal.
The door knobby-thing pushes against a tab (inside the door) ... if the knobby-thingy-deal is worn, I would BEND the TAB that it pushes, so it's closer the the knobby-whatchamacallit-thing.
LOL! I'm a great communicator, ain't I?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I understood exactly what you said Alan... scary. | | | | | Joined: Mar 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 28 | So my question is: Can I put the passenger side door handle or lock or the driver's side (since the drivers side does not have the key lock on the outside) and will it work?
thanks
Jeff | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Jeff - does on the 55-59 trucks fer sure
Bill | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The push-button handles (52-early 60s, at least), can be swapped side-to-side. A competent locksmith shop can re-key a button to match, so you don't have to buy new locks. This doesn't cost much. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | 54-59 ... you can switch the handles, but it'll work backwards!
The push-button locks; no problem.
