0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 23 Apprentice | | Apprentice Joined: Aug 2004 Posts: 23 | Trying ro remove some small clutch head screws from the interior but they dont want to budge any suggestions on removal? Thanks | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I used PB Blaster, a couple of love taps,let sit,maybe get a few blisters,couple of brews,some choice words. It worked. Only had to grind off one out of complete interior of my 4t6. Good luck
Dan | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Took my dremel and a small cutting wheel and cut slots in them. Then went to a bolt shop here & bought phillips screws. Not original but functional. Jim | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | ive found taping the driver with a hammer while aplying constant presure works great.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Tightening first before loosening sometimes works. On tough ones I use heat. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Patience, heat, PB Blaster, pressure, tapping and tightening before loosening all work. I have removed the screw tip from the driver and inserted it into the problem screw and tapped it a few times after letting PB do its thing. If all else fails drill the screw out and try removing with a screw extractor. They are available in a variety of sizes from your local hardware store, home center or auto parts supplier. Best of luck with your problem screws. | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | use of a clutch head socket and an impact driver along with a good penetrating oil is the best way I have found over the years. | | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | If you have access to a wire welder, tack a 1/4" nut onto the head of the screw. The wire is small enough to weld inside the nut. The heat from the coupla seconds of welding should also be enough to loosen the threads. A little penetrating spray, and a wrench or socket on the nut should get it off. | | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | PBblaster and really tight vice grips on the head worked for me on a number of clutch head screws on my 50 3600 truck. A few I had to heat with a plumbers torch then PBblaster on them. Let the PBblaster sit a 1/2 hour or so. Tap with a hammer a bit, then crank a set of vice grips on the head and give a twist. | | |
