| | | Forums66 Topics128,091 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 58 'Bolter | | 'Bolter Joined: May 2004 Posts: 58 | Hello People, I'm restoring a 1950 3800 One ton. Looking for suggestions on the best way to clean the old gas tank. Just took the cab to the body shop, should have it back within a couple of weeks. Thanks in advance for any suggestions...Clint | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I take them to the local radiator shop, they clean them for $40. Pressure washer works well if not too cruddy. Brian | | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | Local radiator shop boiled mine out and lined it for $80. Just like new!!  | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Like the other guys, I had the radiator shop boil it out. That got the old crud and varnish out, but there was still surface rust inside. I was concerned that this would flake off, so I filled it with water with a mild acid solution and left it for a couple of days. After rinsing it out, there was still some rust, so I repeated the process. Now the tank was smooth inside so I poured in the sealer (liner) as per the instructions on the can. Result: no leaks and a clean fuel filter. (I had cut open the old fuel filter and it was full of rust, so I knew I had a problem)
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | I have the same problem, good tank on the outside, really rusted on the inside. What type of acid solution did you use to clean the inside? I'd really like to salvage the tank. http://www.geocities.com/pickinjim1/Jims51truck.html | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I used muriatic acid because it was easily available at the paint store, but a lot of people people prefer phosphoric acid.
I was not worried about acid embrittlement (aka hydrogen embrittlement) since modern tanks are galvanized and one of the first things they do in the galvanizing process is pickle the metal in hydrochloric acid.
