0 members (), 128 guests, and 0 robots.
Topics128,035
Posts1,055,560
#162030 05/27/2004 2:35 AM
Junior Member
Junior Member
My 55.1 Chevy 3100 series truck has a problem with the passenger side window regulator. I can push the window down with the window handle spinning..actually, I can push the window down or pull the window up. Any ideas? Thanks..
Bob
#162031 05/27/2004 4:00 AM
does the window handle move the window at all? or is the pushing up/down independent? These things are just pressed metal so they aren't all that great. I had one that did the same thing and the teeth were stripped out so I got aftermarket ones - fairly cheap and easy to replace.
#162032 05/28/2004 2:11 AM
Junior Member
Junior Member
The window crank will roll the window up or down. Just doesn't lock it in place.
Bob
#162033 05/28/2004 3:57 AM
Sounds like you need new springs.
Chevy Duty part #18-781 ... $3.95 each ... 1-800-741-1678
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#162034 05/28/2004 11:42 PM
Junior Member
Junior Member
Thanks for the help guys...$3.95 for a spring is a lot cheaper than $75.00 for a new regulator. Bob
#162035 06/01/2004 2:00 PM
need to replace/repair window regulator on my 54. are those things bolted or welded in there and how in the heck do you get in there to work on it?? any tips appreciated.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#162036 06/01/2004 8:07 PM
I'm pretty sure they're bolted in ... but it doesn't look like a real easy task from what I remember -- I put new vent windows in earlier this year and was planning on putting new springs in the window regulators at the same time ... but I decided to skip it -- it must've looked like a real pain in the butt or I would've done it.
My passenger-side window was drifting down about a half-inch ... I'd crank it up, then after about an hour of driving, it would come down, so I was gonna put new springs in the regulator. Then, like I said, I decided to skip it, and after putting the new vent windows in, both windows are nice and tight and the passenger-side stopped coming down.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#162037 06/02/2004 3:00 AM
Junior Member
Junior Member
These window regulators are bolted in...4 if I remember right. But to get the regulator out the vent assembly and window has to come out. Be careful when removing the windows, they do break easily [personal experience].
Bob
#162038 06/02/2004 3:08 PM
thanks for the info. the section that the glass fits in is not even attached to anything. i did have a good window but i let it lay loose in there too long as did the previous owner - now it is cracked. does anyone know how the piece that the glass goes in attaches to the regulator. i tried to look on the other side but can't tell very much about it. again thanks for the info. you all sure have some nice looking trucks!!
#162039 06/03/2004 2:45 AM
Junior Member
Junior Member
On my 55 1/2 ton a horizontal rail is fitted to the bottom of the window. Regulator arm with roller fits into this rail/track .As you crank the regulator, the arm raises or lowers the window. Yours is probably similar to that.
Bob
#162040 06/03/2004 3:11 PM
i can see the little roller you are talking about. in fact the window was resting on it! now i have to figure out how to get the (a) glass back in the track and (b) the track hooked on the roller. thanks 4j. it will be another week before i will be back in okla where my truck is. i try to get on here and get all the info i can get, print it off and work off the info i recieve. thanks again
#162041 06/03/2004 7:52 PM
You can see by this picture that the glass sits in a metal rail, like Bob says. With the window tilted (as seen below) it should fit into the regulator arm -- I hope this helps:
[img]http://www.alanhorvath.com/54chevy/chevypics/window_felt.jpg[/img]
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#162042 06/07/2004 2:37 PM
thanks for the pics alan, nice truck by the way, another question for you - can the metal strip that the glass sits in be put back on and then the window put back on the regulator without taking the vent window out??
#162043 06/07/2004 6:33 PM
I don't think you can get the window out, or put it back in, without first removing the vent window. But removing the vent window isn't that difficult ... I think the most difficult thing is putting the vent window back in; getting the door window into the felts -- and even that isn't too bad; just takes a little patience.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
Moderated by  ndkid275, Phak1
