5 members (HandyAndy, klhansen, Guitplayer, Hanks custodian, Hugh63c10), 90 guests, and 0 robots.
Topics128,092
Posts1,056,043
Members48,433
#161955 08/16/2004 11:14 PM
Junior Member
Junior Member
I just bought a 72 pick up and while washing it the other day I noticed a lot of water leaking from the door panels on the inside of the door. Is there supposed to be weather stripping on the panels to prevent the leaks?
#161956 08/18/2004 7:33 AM
The panels shouldn't be leaking ... maybe it's your door rubber ... OR you might want to put "shower curtains" behind the panels -- remove the panels; wherever you see an opening in the DOOR, take a piece of plastic (heavy duty garbage bag) cut larger than the hole; tape it above the hole with some duck tape and then tuck the bottom of the plastic IN. That way, water comes down, inside the door, from the window ... hits the plastic, and continues to run down inside the door instead of hitting the back of the panel and running down that.
Hope that helps.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#161957 08/18/2004 12:19 PM
Junior Member
Junior Member
Thanks for the reply. I was thinking along the same lines. The door rubber and window felts are new and in good shape. I guess the water hitting the window is running down inside the door and leaking out into the cab via the door panels. I thought perhaps they make a gasket for the panels to seal them up. I'll try the plastic trick.
#161958 08/18/2004 2:49 PM
Nice deer pics gator. Did you get that buck with a bow or gun? I am gearing up for the opening of Wisconsin's bow season, Sept. 18 and can't wait.
Chris
Chris 1955FirstSeries
#161959 08/29/2004 4:43 PM
Junior Member
Junior Member
Thanks Chris. I shot that deer during last years muzzloading season. I shot him at about 60 yards out with my CVA Firebolt .50 cal. My son and I didn't get an early deer season draw this year but we did get a draw at a big time wild hog place for muzzleloaders. I can't wait either!! Good luck!! grin grin
#161960 09/05/2004 3:28 PM
Junior Member
Junior Member
Gator, you probably want to check the bottoms of your doors to be sure the drains are clear.I would think the water you are seeing would be more likely to drain out them than the door panels.I used a heavy cloth and rubber impregnated material(like a gasket material) for inner door liners.It had the advantage of quitening down the cab noise.
My drinking team has a racing problem.
She ain't leaking she's just marking her territory.
Moderated by  ndkid275, Phak1
