1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16172 03/01/2004 12:01 AM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | The threads on my oil pan have never been real great. Changing oil this morning the drain plug (1/2" 20) would not tighten up, threads are gone on the pan side. My tool box had a (1/2 15)so with a new washer, some pipe tape I put it back in. I don't dare over tighter, and it still drips. Will a helicoil work? Or another idea.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#16173 03/01/2004 3:52 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I haven't looked for this for many years, but they used to sell a replacement stopper/bolt that you insert and tighten. It doesn't use the pan threads but it compresses a rubber collar which expands and makes a nice leak proof seal. | | |
#16174 03/01/2004 4:27 AM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Check with a parts store that caters to the professional repair trade, not one of the do-it-yourself places like Auto Zone. There are slightly oversize, self-tapping pan plugs that will cut new threads as they're installed. Dorman Products used to make a line of these plugs, but they've changed company names recently, and I don't remember the new name. Jerry
#16175 03/01/2004 5:50 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 |
#16176 03/01/2004 8:04 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | For those wanting one of the 1/2 " Universal Rubber plug fitting its part #65200 at Car Quest and was $4.89. They also had a 3/4" Universal for $6.19 for bigger holes. Its almost like a toggle bolt whereby you slip in the rubber fitting and tighten up on the wing nut and hope for the best, we'll see tonight.
52pu
#16177 03/01/2004 8:37 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | I think what your talking about is actually a "plumbing thing" (I am no plumber) But I once needed to replace the soft plugs that were in behind the motor mounts on a 351 modified and couldn't get the soft plugs in with the engine in the truck so I went to a plumbing outlet and found what I needed. Worked great. Still is- it is my own 78 F-250 Custom 4x4.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#16178 03/02/2004 2:42 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Does any one know the size of oil pan plug on a 261 pan (58-60)? And where I might find a replacement, which looks like the original, but does not leak like my original?
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#16179 03/05/2004 4:33 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Update: After filing the threads off the pan side as the directions say the 1/2 Car Quest rubber plug PN 65200 worked like a charm. Highly recommend. PS suggestion: after you finish filing there is bound to be some shavings in the pan. Dump a quart of oil thru the engine and let it drain good. This will give you some peace of mind and may pick up a few shavings along the way.
#16180 03/05/2004 5:23 PM | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Filings can be removed with a pocket magnet, too. Just stick it into the drain hole and move it around, then clean off the filings and repeat. Jerry
