5 members (Ponchogl, dt235sd, mason86, Cosmo, Peggy M), 102 guests, and 2 robots.
Topics128,047
Posts1,055,662
#16172 03/01/2004 12:01 AM
The threads on my oil pan have never been real great. Changing oil this morning the drain plug (1/2" 20) would not tighten up, threads are gone on the pan side. My tool box had a (1/2 15)so with a new washer, some pipe tape I put it back in. I don't dare over tighter, and it still drips. Will a helicoil work? Or another idea.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#16173 03/01/2004 3:52 AM
I haven't looked for this for many years, but they used to sell a replacement stopper/bolt that you insert and tighten. It doesn't use the pan threads but it compresses a rubber collar which expands and makes a nice leak proof seal.
1951 1 Ton Completed
#16174 03/01/2004 4:27 AM
H Online: Content
Check with a parts store that caters to the professional repair trade, not one of the do-it-yourself places like Auto Zone. There are slightly oversize, self-tapping pan plugs that will cut new threads as they're installed. Dorman Products used to make a line of these plugs, but they've changed company names recently, and I don't remember the new name.
#16175 03/01/2004 5:50 PM
Thanks guys.
#16176 03/01/2004 8:04 PM
For those wanting one of the 1/2 " Universal Rubber plug fitting its part #65200 at Car Quest and was $4.89. They also had a 3/4" Universal for $6.19 for bigger holes. Its almost like a toggle bolt whereby you slip in the rubber fitting and tighten up on the wing nut and hope for the best, we'll see tonight.
52pu
#16177 03/01/2004 8:37 PM
Oly Offline
I think what your talking about is actually a "plumbing thing" (I am no plumber) But I once needed to replace the soft plugs that were in behind the motor mounts on a 351 modified and couldn't get the soft plugs in with the engine in the truck so I went to a plumbing outlet and found what I needed. Worked great. Still is- it is my own 78 F-250 Custom 4x4.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#16178 03/02/2004 2:42 AM
Does any one know the size of oil pan plug on a 261 pan (58-60)? And where I might find a replacement, which looks like the original, but does not leak like my original?
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#16179 03/05/2004 4:33 PM
Update: After filing the threads off the pan side as the directions say the 1/2 Car Quest rubber plug PN 65200 worked like a charm. Highly recommend. PS suggestion: after you finish filing there is bound to be some shavings in the pan. Dump a quart of oil thru the engine and let it drain good. This will give you some peace of mind and may pick up a few shavings along the way.
#16180 03/05/2004 5:23 PM
H Online: Content
Filings can be removed with a pocket magnet, too. Just stick it into the drain hole and move it around, then clean off the filings and repeat.
