| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | As is the case with my custom tail light post, this isn't a purist question. Has anyone found a suitable replacement for the stock bench seat? I'm looking for modern amenities, including comfort, power adjust, cup holders and storage. I found a website discussing the use of a 1997 Buick Park Avenue bench seat out of a 4 door that has 6-way power seats and a shoulder strap built into the backrest that looks like a great set-up. Only problems is I can't seem to locate a unit. | | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I have seen several late model tahoe/suburban seats installed ,might find one with all you need. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Take a look at Fatfenders "Toad" project. He is doing a real nice job building a custom ride. I recall he used seats out of a dodge mini-van(?)
| | | | | Joined: Jan 2003 Posts: 10 Junior Member | | Junior Member Joined: Jan 2003 Posts: 10 | I used seats from a dodge dakota p/u , Very comfortable if you don' mind the hi backs. Dodge dakota bench seat will also fit nicely. | | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | What did you install the Dakota seats in? Buckets or bench?
Did you install seats with built in t seat belts? | | |
