| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Doing the windlass on my burb and have run into a little snag. How far down the REAR of the door does the windlass go. Does it stop at the end of the retaining strip? If it goes down further, how does it fasten. I took a lot of pictures of everything but never seem to have the one I need. thanks Jim | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Jim - I don't know if your Burb is the same as my 1/2 ton but mine goes clear down to the floor at the rear of the door. I'd have to look again but I think the retaining strip goes all the way to the floor also. Hope this helps George | | | | | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | Thanks for the info but the burbs and probably the panels have an L bracket right behind the door that is about 4 inches high. I was just wondering what to do with that. Jim | | |
