| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 15 New Guy | | New Guy Joined: Oct 2004 Posts: 15 | I'm trying to install new door window channel in my 50 Chevy truck. What is the best/easiest way to get in in place. Once it's formed and in place what holds it? I'm having trouble determining the right length.
1946 Chevy Flatbed 2 Ton Truck 1950 Chevy 3100 5 Window Cab P/U 1968 Chevy CST 1972 Chevy Fleetside Longbed 1992 Chevy Scottsdale Ext Cab 2000 GMC Sierra Ext Cab | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I used the window glass frame to make a plywood pattern. I first measured the rear channel length, from the elongated slot that a clip on the old channel locked in, this gave me the approximate height, after forming I used several sheet metal screws thru the channel into the door frame, I think #4x3/8. Small enough that they bury themselves in the fuzz. I think Alan Horvath has a web page on the later models with wing windows. Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I just did mine and it went much better than I had feared. I used the window glass (removed of course) to bend the channel around. This worked fine and the fit in the frame was great.
My vehicle had stainless holders for the ends (screwed in to the door), I measured with the channels dry-fitted in the frame, then used adhesive to glue the stainless holders to the ends.
After the ends cured, I put adhesive on the window frame where the channel would fit and put the channels in place.
I used masking tape to hold the channel in place while the adhesive cured. | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Mine is a 49 (ventless). I just did this also. Was not as bad as I expected. The only problem was that I forgot that the exterior reveal molding has to be in place before putting in the channel, so I got to do it twice. I used a few small pop rivets to hold the channel in the window frame and they worked great. Good luck with yours | | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I have a 54 with vent windows. I removed the keepers that hold the channel against the outside from the old channel. Then pop-riveted them to the new ones. They stay in place and can be removed if needed. Steve | | |
