0 members (),
139
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 36 Junior Member | | Junior Member Joined: Jan 2003 Posts: 36 | I need information where I can get the "clips"that go under the trim piece that fits next to the windshield on the inside of the cab. Anyone know where I can purchase or where I might find any used ones? | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Here's a catalog in PDF format that has clips of every kind, size and shape imaginable!: RestorationSpecialties.com
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | RHuddle56,
Restoration Specialties is an excellent company. They are quick, helpful, and friendly. If you have an example of a small/odd piece of hardware, send them the part and they will try to match it (and they will return the original part).
I am now putting together a 1954 truck and installed the windshield "trim bar" on Sunday. This is the the "trim bar" that scrwew into the dashboard near the windshield and it directs the "defroster" air towards the windshield. There were no clips - the screws (6) attached directly to holes in the dash.
Maybe I am referring to the wrong part? Can you post a picture?
The only clip I see is one on each of the two defroster "funnels" (vents/scoops?) that attach from under the dash (each with a screw on one side and a clip on the other side).
Tim | | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | All, I have the same problem on my 55.1. No clips, except a couple of rusty survivors. I think I'll try the sources you metioned. By the way, they are just a bent tempered wire. - Scott
55 1st Chev.
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I was given a 54 GMC cab 2 weeks ago and it has the upper dash trim. I will try to get to it and remove the trim to see the conditions of the clips.
Joe
| | | | | Joined: Jan 2003 Posts: 36 Junior Member | | Junior Member Joined: Jan 2003 Posts: 36 | Chevy 1 that would be great. you should be able to Email me. Thanks RHuddle56 | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | RHuddle56, the clips (windshield inside vertical connectors) you want are available from Jim Carter, $5.95 a pair, item # WIC304. www.oldchevtrucks.com OOPS, these are for 47-53, I see yours is 54.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Well I loosened up the upper dash trim and what do you know.....all the clips appear to be there I can't post pictures but if you would like to email me.....I will send you a picture of what they look like.
Joe
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | To All, That Restoration Specialties rang a bell, and now I remember that I did send my rusty clips to them and they were unable to match it. They sent mine back. So I am still looking. - Scott
55 1st Chev.
