Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (54farmtruck, Wayne67vert, Bill Hanlon, 1 invisible), 166 guests, and 2 robots.
Topics128,299
Posts1,058,705
Members48,493
#1615607 11/20/2026 7:19 AM
I bought these rims on facebook marketplace, seller said they were off his 3600 gmc truck. I bought them to replace my 53 3600 Chevy truck rims, Don’t want split rims anymore. The rims I bought are 16” x 6” wide. I didn’t think they had rims that were not split as an option. need another rim. What year or make are they.
jrs48pu #1615622 11/20/2026 6:14 PM
Hard to tell, as that bolt pattern was real common in later years. Probably shared by all the truck manufacturers. Are there any markings on the wheels? Those would be stamped on the back side of the rim.
[on edit] Would those rims by chance be 16.5 x 6? 1969 C20's used 8 on 6-1/2 lug pattern.
Last edited by klhansen; 11/21/2026 7:34 PM. Reason: added more info - fixed bolt pattern number
jrs48pu #1615661 11/21/2026 2:10 PM
AD Addict & Tinkerer
I agree with Kevin, they might not be original to the GMC it came off of. Additionally, I don’t believe, GMC and Chevy used the same designation for their truck models. I believe a 3/4 ton GMC would be 150 (FC152 in the vin ID) and not a 3600 like Chevy uses. Measure the rim at the point the bead will seat to find the diameter of the rim. Same with the width.
Phil
Project Journals
Stovebolt Gallery Forum
jrs48pu #1615679 11/21/2026 8:38 PM
B Online: Content
1939-53 GMC Master Parts Book does not list any 8 bolt 16"x6" wheels.
The only 8 bolt 16" wheel listed is a 16"x5.50" with a 6.5" bolt circle, a 4.5" hub size and a 13 13/16" backspace.
Moderated by  klhansen, Rusty Rod
