Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
I bought these rims on facebook marketplace, seller said they were off his 3600 gmc truck. I bought them to replace my 53 3600 Chevy truck rims, Don’t want split rims anymore. The rims I bought are 16” x 6” wide. I didn’t think they had rims that were not split as an option. need another rim. What year or make are they.
Hard to tell, as that bolt pattern was real common in later years. Probably shared by all the truck manufacturers. Are there any markings on the wheels? Those would be stamped on the back side of the rim. [on edit] Would those rims by chance be 16.5 x 6? 1969 C20's used 8 on 6-1/2 lug pattern.
Last edited by klhansen; 11/21/20267:34 PM. Reason: added more info - fixed bolt pattern number
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I agree with Kevin, they might not be original to the GMC it came off of. Additionally, I don’t believe, GMC and Chevy used the same designation for their truck models. I believe a 3/4 ton GMC would be 150 (FC152 in the vin ID) and not a 3600 like Chevy uses. Measure the rim at the point the bead will seat to find the diameter of the rim. Same with the width.
Phil Moderator, The Engine Shop, Interiors and Project Journals
1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc Brakes Project Journals Stovebolt Gallery Forum
1939-53 GMC Master Parts Book does not list any 8 bolt 16"x6" wheels.
The only 8 bolt 16" wheel listed is a 16"x5.50" with a 6.5" bolt circle, a 4.5" hub size and a 13 13/16" backspace.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
