Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (54farmtruck, Wayne67vert, Bill Hanlon, 1 invisible), 166 guests, and 2 robots.
Topics128,299
Posts1,058,705
Members48,493
#1615625 11/20/2026 7:51 PM
I’m considering lowering my ‘54 2-3”. I understand that I can lower the rear by swapping the location of the springs but I wonder if that upsets the geometry of the torque tube diff to the tranny. Also, what’s the easiest, cheapest way to lower the front using the stock axle AND put in disc brakes using original wheels?
Brian
Ribside #1615627 11/20/2026 10:06 PM
Lowering the rear won't really affect the u-joint much. It will reduce the angle. You don't want it completely straight (although that may only apply to u-joints with needle bearing cups) but it'll probably be a couple degrees. You should loosen the pivot bolts on the spring mounts until you have it setting where you want it and then tighten those to normalize the rubber bushings in them.
Can't really say about the front axle short of new flatter springs if you're using the stock axle.
Ribside #1615639 11/21/2026 3:14 AM
Any kind of lowering method involving using the stock axle will severely limit the suspension travel. The vehicle will bottom out on bumps. The simplest (and most expensive) option will be a dropped axle.
Ribside #1615653 11/21/2026 7:26 AM
On looking at pics of my truck (which should be similar to your 54), I don't think changing the location of the springs in relation to the rear axle will help much, as the springs are already under the axle tube.
Ribside #1615657 11/21/2026 1:27 PM
Donald S.
Donald S.
Brian, I put lowering springs all around my truck. Hot Rod Lincoln is right it does bottom out in the front only. I like the look of the slightly lowered stance. I did have to make a new leaf spring shackle to raise the back 1” as my wider tires slightly rubbed my fenders.
1949 Chevy Carry All
Follow the resto in the Project Journals
1953 Chevy 5-window
"Frame off Restoration"
Follow the resto in the DITY
Please don't tell my wife how much this thing cost!
Ribside #1615659 11/21/2026 1:54 PM
Crusty Old Sarge
Crusty Old Sarge
I have a 4 inch drop axle on my '59. The axle is one of Nostalgia Sids, he does really quality work. If I were to do it?again I wouldn't use as deep a drop, 4 inches puts the axle pretty close to the pavement. I currently have 15 inch wheels and tires.
https://droppedaxles.com/
'59 Apache 4 inch drop axel
4 inch drop axel 2
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
