0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I took my 1951 1 Ton doors apart on the weekend, getting ready to have them stripped. Now I see that the window regulator has a small rubber grommet type affair that runs in the window lift track. Has anyone found a method for replacing these? It seems a shame to replace the whole regulator for such a small part. | | | | | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | Since the cab/doors are the same between the 1/2, 3/4, 1 T, and 2 T you might find another part from a donor vehicle if a replacement part is not available.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
