Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Ponchogl, Bill Hanlon), 160 guests, and 4 robots.
Topics128,282
Posts1,058,632
Members48,493
#1615584 11/19/2026 5:43 PM
Does anyone know if the grommet for the bolt is still available? Also a good source for the brass fittings. SC-650. And whats with the grove on the bolt is that for some type of O-Ring
Thanks Shady
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
I can't answer about the grommet for the bolt or the groove on the bolt (yet), but you can get new fittings and flex lines for your filter canister from Jim Carter under ME739.
Others will likely chime in on the grommet and grove questions here at some point. wink
~ Dan
1951 Chevy 3 window 3100
O Online: Content
The groove is for a retaining clip or E clip to hold the bolt captive.
1950 Chevrolet 3100 (Ol' Roy)
