Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Hello everyone, I was looking through the forums for some possible guidance and didn't come up with much.
I have a '59 chevy with a 235 I6 and the rochester carb and oil bath air filter. I've had the cam driven mechanical fuel pump die on me twice in the last two years. Two different failures. first one was the pumping diaphragm cracked and the other was the breather membrane, if that's what it's called. I have two options. Get the mechanical pump working again or replace it with an electrical fuel pump.
I like to keep the truck original as I can, but would like the added reliability of the electrical pump (or so I think. Could end up being less reliable).
My question is: Would rebuilding the pump be better/cost effective, or wiring a new electrical fuel pump in give me added reliability? This engine is about as original as it comes to my knowledge.
Any guidance opinions is welcome. Trying to decide as I would like to use my truck more often for lumber runs.
