Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (59Kid, Rosco, 49nut, Ghost_Rider), 148 guests, and 0 robots.
Topics128,280
Posts1,058,590
Members48,492
#1609947 08/23/2026 11:34 PM
Hello, what is the best media to use when sandblasting inner doors
thanks James
41 chev #1609966 08/24/2026 2:46 AM
Definitely NOT sand! Glass beads do much less damage to the base metal- - - -sand and similar blast media will peen the metal and produce a ripple effect that's almost impossible to sand smooth again.
41 chev #1610015 08/24/2026 5:56 PM
I prefer 60 grit garnet.
41 chev #1610048 08/25/2026 12:06 AM
You can warp the metal with about any media. You have to watch your air pressure. Mark’s 60 grit garnet is a good choice.
41 chev #1610262 08/27/2026 9:46 PM
What should the air pressure be set at and where can I get 60 grit garnet?
41 chev #1610264 08/27/2026 11:12 PM
Most industrial supply houses have 60 grit garnet or a suitable media. Harbor Freight even has sandblast media They have 80 grit glass beads, which I have used successfully, and a coarser 70 grit aluminum oxide media. Both are finer than 60 grit, so less aggressive.
I would start at about 50 psi and see how it works.
41 chev #1610276 08/28/2026 1:48 AM
James - Just a safety note, whatever media you use blasting, be sure to wear a quality respirator and eye protection. You do not want to breathing any of the debris/media dust as it can really cause permanent damage to your lungs.
Safety First! thumbs_up
~ Dan
1951 Chevy 3 window 3100
41 chev #1615538 11/18/2026 6:02 AM
Thanks guys
Moderated by  ndkid275, Phak1
