Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (78buckshot, cmayna), 111 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
Hello
I bought a new set of wires for the spark plugs and they came thru with no boots on plug ends. Although the look primitive they work fine.
I’ve seen in photos where some 36s have boots at distributor and plug ends while others show wire set with boots only on distributor.
My ? being — are both correct? One or the other correct.
I do like them without (promise no touch when truck running) yet I also like to have truck as close to correct as possible.
Thx
Boots/no boots?
D Online: Content
i think it was 1953 before the plug wires had boots from the factory.
Thom - I scanned through the GM Heritage files 1936 Chevrolet Truck Data pdf
and this 1936 Chevrolet Truck Dealers Sales pamphlet and unfortunately neither provided that detailed info on the original spark plugs wires having boots or no boots on the plug end.
Perhaps there's another 'Bolter with more experience on the '36's that will chime in?
~ Dan
1951 Chevy 3 window 3100
O Online: Content
1953 was the first year for widespread use of plug wire boots at the plug end of the wire across the industry. Chevrolet and Packard are notable. Nearly all cars used bootless plug wires through 1952. Ford started in 1951 with certain models and everything got them in 1953. Cadillac did it in 1949.
I think its safe to say that your 1936 Chevy came without boots.
1950 Chevrolet 3100 (Ol' Roy)
I remember a 1950 GMC that my father purchased new had no boots.
Here is a picture of a 1936 GMC that I believe has the original wires, looks like metal 90 degree connectors onto the plugs.
1936 GMC T-14 1/2-Ton Pickup
