| | | Forums66 Topics128,288 Posts1,058,579 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2026 Posts: 5 'Bolter | | 'Bolter Joined: Nov 2026 Posts: 5 | Hello How do I post photos of truck to this forum. This new age stuff is a little tricky for me Yes, I’m one of those! But, although an old dog, I can be taught. Thx | | | | | Joined: Mar 2000 Posts: 1,189 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,189 | Look in the left hand column. Sixth one down. | | | | | Joined: May 2015 Posts: 11,282 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,282 | In case you're on a phone and can't see the left column spot that Paul pointed you at, try this: Posting a photo on an iPhoneAlso here's another on a PC (you don't have to enter a caption, but it's a nice thing to see). Posting a photo with a caption
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2019 Posts: 4,548 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,548 | I found that if you rotate the phone sideways, the left column shows up.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
