Brrrr
place holder
6 members (TexasFarmTruck, ShopRag, TUTS 59, Phak1, JW51, TexasJim50), 73 guests, and 4 robots.
Topics128,271
Posts1,058,417
Members48,485
#1615334 11/13/2026 7:41 PM
I'm working on rebuilding a 270 GMC and the seal surface on the crank is pretty pitted and has been already been ground undersize a little. I'm considering modifying the block to accept a rubber rear main seal.
I found a Garlock split seal that is a size that I can counterbore the back of the block to accept the seal. (see pics)
Boring out the block should be fairly easy. I can set the block on my mill sitting on the top deck and be able to bore it using a right angel head on the machine. The installation instructions call for a seal retainer to be installed which I can make and retain with some small flat head screws. With the one-piece design of the split seal it will require me to put the seal on the crank before setting it in the block but I think that will work ok.
Basically I was wanting to bounce the idea off folks in this forum to get your reaction to the idea. Do you consider it a workable idea or would you say no way?
That might work. Do the seal ends need to be glued together? Also it looks like your seal retainer would need to be a 2 piece affair, secured to the block and the main cap separately. That flywheel flange on the crank sure makes this harder than putting a full circle seal on a Chevy. I did that on my 216 when I put the 235 crank in it.
Yes, the retainer will have to be two piece. The instruction only say to orient the split in the seal towards the top but no mention of sealing the ends.
It would definitely be much nicer if it didn't have the flywheel flange.
