| | | Forums66 Topics128,281 Posts1,058,460 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | Is it possible to replace a rocker assembly from a 1954 235 with a set from 1959 through 1962 by just removing the 1/16" restrictor under the side cover. I am building 2 new 848 heads and would like to have better oiling to 1 and 6.
Thanks Shady | | | | | Joined: Dec 2020 Posts: 284 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 284 | In 59-62 the holes in the rockers do not line up with the holes in the shafts. They require more pressure to then weep out though the clearances. If you can get the oil passage to supply enough pressure, it should work. The 59-62 rocker shaft does not dump at the connector in the middle, thus pressurizing the rocker shaft and ensuring all the rockers get oil to the weep holes.
1947 3600 Chevy
| | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | I was thinking about changing the entire shaft and rocker system complete from 59? I am sure someone has tried this over the years. Just asking as I don’t need an expensive mistake.
Shady
| | | | | Joined: Sep 2009 Posts: 6,215 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,215 | Shade Baby - Here's a recent thread that discuss a lot about the rocker shafts and differences in oiling paths for the 235 heads depending on year of manufacture. Lots of reading, including the links provided, that should offer you some info to help understand what's going on and possibly give you some insight on the rocker assembly swap your considering.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2023 Posts: 284 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 284 | Thanks for all the help, I will rebuild the 1954 rocker assembly, and make sure everything is clean.
Shade Baby
| | | | | Joined: Sep 2009 Posts: 6,215 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,215 | If you find you need new rocker shafts, I'd suggest you go with this set (pair) of ME242 Rocker Shafts from Jim Carter. His price is the best by far that I found! They are what I bought recently to replace my worn out shafts on my 261 being rebuilt.
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Rocker shafts only wear on the bottom. It's possible to turn them upside down, drill new oil holes, and plug the ones on top with brass dowels to correct the oil flow. Use a solid carbide drill bit, as the shafts are hardened all the way through. Jerry
