8 members (Gdads51, tclederman, Donf, Forty9, Oswald, J Lucas, sron48, Peggy M), 115 guests, and 1 robot.
Topics128,286
Posts1,058,286
Members48,483
I don't know if all '47.2-55.1 17" split rims are the same. I need just one.
Carl - The 8 lug 17" split rims (wheel + clamp and side rings) where all the same from 1947 - 55.1 for the 17 x 5.0 with 1/2 offset used on both 3600 and 3800 trucks.
Hope someone has one to fill your need. I'll take a peek to see if there's anything in your vicinity on the web and report back if I find anything. wink
Best of luck in your search! thumbs_up
~ Dan
1951 Chevy 3 window 3100
I have some 17" 8 lug rims but I need to check which style they are (I beleive I have 2 different styles). I'm not close by but I can make you a good deal if I have what you need.
Can you send me a PM with how best to determine if one of my rims would meet your needs?
1949/50 3600 Project
Follow in Project Journals
Moderator
Moderator
2 Offline
I may have one for you Carl but have to check the size. New dry rotted bias ply tire mounted on a 3 piece rim and holds air good.
If it is the right one, pick it up free next June in Townsend Tn.
I'll check latter today, it could make a good spare.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Carl if these fellow 'Bolters might be "way too far" afield for you, there's one a bit closer, up in Lyndonville, NY (NW section of the state).
Still a long road trip from VA (local pickup only) for one wheel and his $100 asking price seems steep IMHO. frown
https://www.facebook.com/marketplace/item/2186565635522398
I'll keep looking. smile
~ Dan
Haunting the SBP since 2001
I have a nice complete & serviceable original 3 piece 17'' rim for 1947- 1955.1 , 3/4 &1 ton trucks... & it still retains all of the hubcap clips.....
Once again...The shipping price from Rust Free Arizona to VA. will probably cost more than the rim...
