| | | Forums66 Topics128,278 Posts1,058,251 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,334 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,334 | I don't know if all '47.2-55.1 17" split rims are the same. I need just one.
| | | | | Joined: Sep 2009 Posts: 6,167 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,167 | Carl - The 8 lug 17" split rims (wheel + clamp and side rings) where all the same from 1947 - 55.1 for the 17 x 5.0 with 1/2 offset used on both 3600 and 3800 trucks. Hope someone has one to fill your need. I'll take a peek to see if there's anything in your vicinity on the web and report back if I find anything.  Best of luck in your search!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Nov 2021 Posts: 1,439 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,439 | I have some 17" 8 lug rims but I need to check which style they are (I beleive I have 2 different styles). I'm not close by but I can make you a good deal if I have what you need.
Can you send me a PM with how best to determine if one of my rims would meet your needs? | | | | | Joined: Aug 2001 Posts: 3,632 Moderator | | Moderator Joined: Aug 2001 Posts: 3,632 | I may have one for you Carl but have to check the size. New dry rotted bias ply tire mounted on a 3 piece rim and holds air good. If it is the right one, pick it up free next June in Townsend Tn. I'll check latter today, it could make a good spare.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Sep 2009 Posts: 6,167 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,167 | Carl if these fellow 'Bolters might be "way too far" afield for you, there's one a bit closer, up in Lyndonville, NY (NW section of the state). Still a long road trip from VA (local pickup only) for one wheel and his $100 asking price seems steep IMHO. https://www.facebook.com/marketplace/item/2186565635522398I'll keep looking.
