Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
Since I’ve detected that crankshaft cap bolts on my engine are different lengths and diameters I found the Attached is Google search for 235 crankshaft retention caps bolts.
The attached does not provide length of bolts for cap 1,2 & 3
Can someone tell me the length and diameter for bolts at the 4 caps?
The first three caps are 9/16-12 thread. I'll give you a length measurement tomorrow morning when there's enough daylight in the storge building to get accurate measurements. The rear cap uses four 1/2-13 bolts. Ditto on the length measurement tomorrow. Use Grade 8 bolts.
Do you need some or is it a curiosity? I have some to spare, all lengths, if that helps.
1954 3600 Stakebed
non-original engine out of a '55 passenger car with powerglide
I’m pretty certain that I’ll needs some, specifically the 4 bolts for the rear cap
See whoever repaired this engine, unknown date, for I can tell so switched bolts from some other engine or what they had on the shelf
Jerry is going to shortly provide length
