Man, sorry to hear that. If it were mine, I would leave the engine in the truck and pull the heads. The 355 that I built years ago was drinking oil at an alarming rate, when I was farming out the machine work originally, I took the heads to a shop that was recommended, bronze guides, 3 angle grind, umbrella seals. I pulled those heads and replaced them with another set of cast iron medium valve units but had another machine shop do the head work. Along with the head swap and pulling the big block oil pump and putting in a small block normal capacity pump, the oil consumption problem disappeared.
I considered leaving the engine in the truck but working over the fenders to remove much, especially heavy things like the heads doesn't sound like a plan. I may take the carb and intake off to check for oil being sucked in from the valley (wishful thinking, I know) but that would be the limit I think.
If you still have the 235 , get it rebuilt. At our age , who cares about how fast we get there. Most important ...how it sounds. Making a bunch of noise but still cannot go faster than a hyndai, seems silly. Only thing I pass out here are tractors and amish buggies.
Or buy a crate 350 and sell the 383. Quicker that way.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
I finally decided to determine what my approx fuel consumption is and based on one fill and roughly 100 miles I calculated it is in the 8 mpg range. I knew it wasn't good, but didn't expect it was that low, so I am wondering if my oil consumption problem may be associated with excess fuel washing down the cylinder bores resulting in bore and ring wear.
The engine has always started and run well, generally starting without the aid of the choke so I should have suspected it was pretty rich and I do not expect the fuel consumption to be very good.
If the oil problem is associated with excess fuel is it likely that the 1000 miles I have on the engine has worn it to the point that it needs to be honed and new rings installed or can I lean out the carburetor and avoid pulling it out and apart? I know there are a lot of piston miles traveled in the bores for 1000 miles but if I can avoid pulling the engine out/apart it would be desireable.
Regardless I need to detmerine how best to get the carburetor calibration closer to desired (whatever that means). Is there a good way to determine the proper jetting other than trial and error? I do not have an exhaust analyzer but may have a shop nearby that could help with this if that is the way to go.
I should add that the engine runs very well, pulls good through the rpm range with no bogs or indications of being too rich. The tailpipes have black soot and while it has been a while the plugs indicated (see earlier post in this thread) it was running a little rich but not so much so that they are sooted.
Get a A/Fuel Ratio gauge from EBay or Amazon. Hardest part of install would be welding the bung for the sniffer (sending unit) in one of the exhaust pipes just in front of a muffler. I would think a.ratio in the 13 or 14 to one range would be what you’re looking for.. personally, I believe if it’s running so rich that it’s washing the.cylinders then it would probably be diluting the oil as well. You would be able to smell the gas in the oil.
1966 C-10 Short Stepside HiPo Step-by-step ~ and on-going resto build in the Project Journals
I'm running a Holley 3310, I believe it is 750 CFM, has vacuum secondaries, air filter is a smaller element after market (I need to measure the size), the intake manifold is an Edelbrock Performer 2104. The carburetor was rebuilt by me before being installed but I do not seem to have a record of the main jets in place.
There was not evidence of gas in the engine oil so I suspect that was not the problem.
I pulled the intake manifold and there is no evidence that there was oil coming in from the valley so I pulled the front clip and plan to pull the engine for dissassembly and inspection.
The good news is all the bolts associated with the front clip as well as the engine were recently installed so not fighting hardware like a normal vehicle dissassembly process.
November is a busy month so while I plan to get the engine out and the heads off I doubt I will get much further until after Thanksgiving.
The Edelbrock 2104 and the Holley 3310 should be a workable combo, primary jets should be 70-72, you might go as small as 68's. Make sure the secondary throttle plates are fully closed at idle. You might want to double check the float level on both sides. If you are at all concerned about air restriction, go as big as you can on the filter, restriction will richen the A/F mixture. When you built the engine do you recall what compression ratio you were shooting for, and what size intake valves, combustion chamber c.c.?
The air filter is 11" dia by 2" tall, so on the small side. I believe the combustion chambers are 64cc and I calculated the CR to be 9.7 static, 8.1 dynamic. I have the Comp XE268H-10 cam.
I pulled the engine out and removed the heads. Generally the plugs looked worse than previous (more deposits, darker color) except #8 that was very white (need to investigate potential coolant leak into #8). There was nothing noteworthy about the combustion chambers or pistons, and bores still have some of the cross hatch. Cylinder #1 looked about the worst for deposits on the plug so I may pull the intake valve to evaluate the valve to guide clearance.
Until I pull pistons and check the rings it is a guess but I suspect that the rings are stuck (not free floating) in their grooves and it may be a result of the long delay between engine assembly and first firing ( roughly 3 years).
