Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
#1614552 11/02/2026 12:51 AM
Looking for opinions on the Remflex intake/exhaust gasket. They claim it's thicker than stock to correct warping problems up to 1/16". Anyone use it for this purpose?
Product Description:
-Heating and cooling of the exhaust system causes header and manifold flanges to warp resulting in gaps between the head and header which Remflex exhaust gaskets seal completely due to the thickness and compressibility of the 100 percent flexible graphite
-Remflex exhaust gaskets come in a standard 1/8 inch thickness and are designed to crush 50 percent allowing them to fill any pits or gaps in the flange surface up to 1/16 inch
D Online: Content
I installed one on my '54 235 engine, and it made a big difference vs the Fel-Pro manifold gasket.
Did you have a leak or a warpage problem prior to installing them?
D Online: Content
yes, two previous fel-pro manifold gaskets never sealed fully (did the job twice over a couple years, not two stacked gaskets). I did not verify, but I suspect the manifolds were the issue.
Crusty Old Sarge
Crusty Old Sarge
My exhaust manifold was warped pretty good. The Remflex gasket sealed it right up. thumbs_up
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Used Remflex on my 54 manifold. Corrected the problem and no issues since installed.
I
I Offline
I installed one two or three weeks ago. Worked like a charm. And easier to install, I'd say, as it's all one piece.
Just make sure and support it well while you're installing it. Don't let it flex and fold or it will snap.
~~ Konstantine
1962 Grumman Olson Kurbside/Chevy P30
Follow in the DITY
Thanks for all the replies. I'm going to give these a try. Mine aren't horribly bad, but I did blow out a set of Fel Pro's.
