7 members (Phak1, Nick in Manitou, Gdads51, Oswald, Greg_H, Wheelie, Bill Hanlon), 127 guests, and 3 robots.
Topics128,208
Posts1,057,708
Members48,475
#1614360 10/30/2026 11:12 PM
Well I have successfully replaced the wire on this wiper motor and it is working. Hope it stays that way. Started with my vacuum wipers were not quite working so I was going to dig into it when I found an electric 6 volt motor on ebay. I did not know they had such a thing, but I guess it was a option. The seller was also Jim Carter truck parts so I knew the description was correct. The only issue was the old wire were it went through the housing was bare wire. After splitting the electric motor, the task was easy to replace the wire. I also put shrink tube on the inner wires as well. After the wires were fixed up, the fun begins to get the brushes back in and get them held in place while putting the halves back together, all while guiding the inner wires to the correct location. I had to walk away a few times from either frustration or hands cramping up, but I am glad I got it back up and running. Now I have to install under the dash.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
KEVINSKI #1614378 10/31/2026 12:41 AM
Is that 6 volt?
KEVINSKI #1614395 10/31/2026 2:50 AM
Yes 6 volt
"The Journey"
Follow in the DITY
KEVINSKI #1614491 11/01/2026 1:28 AM
I wonder where it came from. The fact that it fits puzzles me. Maybe an aftermarket thing from way back when.
KEVINSKI #1614493 11/01/2026 2:15 AM
Maybe but I think there was an option as it has an original wiper switch that came with it that is the same control that is on the vacuum wiper and made by ac delco .There are a few others on there but they looked like they were missing the switch ,not working or rebuilt and more expensive
"The Journey"
Follow in the DITY
KEVINSKI #1614495 11/01/2026 3:31 AM
B Online: Content
39-53 GMC Master Parts Book lists an electric wiper motor part number 2113355 for EC 100 thru 350 models, which were late '46 models. But it looks nothing like your motor.
55-60 GMC Master Parts Book lists a 6 volt electric wiper motor for 55.2 trucks. Only 6v truck in 55.2 was 248 engine with standard transmission.
Part number is 5047825. HERE is one for sale on ebay. The seller has it listed for '54-'55.1 Chevys.
I don't have 54-55.1 GMC parts books.
