Brrrr
Winter is Coming
Stored trucks should have a high-quality security system. A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Guitplayer, greenie-reddy, dt235sd, frogfarmer), 101 guests, and 2 robots.
Topics128,279
Posts1,058,593
Members48,492
I have a 1956 "Goodwrench" replacement engine (it has no serial number markings so I am assuming this) that did not have an oil line from the rear area of the engine to the rocker shaft inside the pushrod galley. Has anyone ever seen this before? I believe it is plugged in the rear. I have it all put together now and I just realized I never saw it during disassembly.... I was watching a YouTube video of someone that found theirs to be clogged, and that was when I realized I may have missed something! Thanks in advance!
55 GMC 3100 2nd Series
71 GMC 1500 Super Custom
1956 Thriftmaster
1954 Blue Flame
1962 Thriftmaster
I have a similar situation with a later 261. The block was cast in 1962 and no serial number indicating it was a replacement block, but had a 1957 261 head on it. When I got it, it had an external oil supply line feeding off a T-fitting on the oil pressure gauge port that wrapped around the exterior rear of the engine and back up the passenger side and then feed into a central oil port in the side of the head just below the valve cover.
Removing the push rod side cover, I also found that the internal ports for the oil feed line normally found under the cover where blocked with threaded plugs.
Turns out that the later block doesn't have the same cast in block oil feed channel to match the earlier '57 head, preventing oil from going to the rockers through the block and a "drilled" head bolt that would normally provide the lubricant path to the rockers in the earlier engines. So for me, that external line is essential to providing lubricant to the rockers and must stay.
It could be your engine is the same, or it's possible that your engine, like many of that period ended up with clogged internal feed path. The Chevy work around fix for that was to install an external oil supply feed like used on mine, plugging those internal ports, and restoring oil supply to the rockers.
I think you made need to confirm what you have for both the block and head to try and figure out what path to follow for getting oil to the rockers. Let us see some casting numbers an date codes from both the block and the head so we can offer more help.
~ Dan
1951 Chevy 3 window 3100
Thanks for the info! The holes in the pushrod galley are plugged with square-head threaded plugs, so I could not have forgotten to put the line back. (see attached) I have an 848 head, and the engine casting is dated 1956, but no serial number stampings. The oil line on the drivers side has a tee, but I assumed the tee line is for an oil pressure gage, but I never saw the truck this came out of. I am really perplexed on what I should do from here. I did not have a line going around the back like yours, so I can't under stand how the oil gets to the valve train!
It's great to have a site like this and I really appreciate your help!
1956 Thriftmaster
1954 Blue Flame
1962 Thriftmaster
My 235 also had an external line similar to Dan's.
1949/50 3600 Project
Follow in Project Journals
From what I can see of your pictures, you have an existing "T" fitting at the oil pressure gauge port. One of those outlets would have fed the oil pressure gauge and the other the external line to the rockers, like on my 261 if I'm presuming correctly.
Before I go down the "unfortunately" road, did the center head bolt on the passenger side on your engine have a drilled hole up through the bottom and out the side of the threads? Here's a 'Bolter "Pre '68 Dave" Blog Post on the rocker oiling system subject and the "drilled" head bolt info that can better describe this than I can. No need to reinvent the wheel me thinks. wink
It's most likely (IMHO based on what's known so far) that with your oil ports behind the push rod cover plugged the same as mine, it's likely you will need to run the external oil supply line to feed oil to your rockers.
The only way I can think of starting to checking things further requires you to remove the head and look to see if the oil passage mentioned in Dave's post is blocked, plus look to see how the oiler that feeds from the head to the rockers is set up.
~ Dan
Thanks Gdads- I knew about the center head bolt, and no, I did not have that on this engine. All bolts were solid as removed. I can see the square-head plug just below the top center of the pushrod galley (see attached); it seems like the line would connect here, but this plug was in it as I received the engine. I also attached a view of the opposite side showing the tee that goes to the oil filter, and the open end that went to....? Again, this is how I received the engine. I have it set up on a start kart right now, so I can at least watch the oil flow to see if there is another oil passage that isn't visible??
Any suggestions are greatly appreciated! Thanks!
1956 Thriftmaster
1954 Blue Flame
1962 Thriftmaster
With out the oil line behind the side cover and no bypass line going to the square plug on the right side of the head, you will have no oil going to the valve train. There are no secret passages in a 235 for oil to get there.
DB - The "square-head plug just below the top center of the pushrod galley" in your picture is not the same "port" I described above. If you relook at my pictures of the external oil supply line to the head, it feeds into a port in the head itself, bypassing that plugged port in your block.
Your second picture with the blue circle and arrow (looks like the way you received the engine?) shows the oil filter canister feed line tapped off that oil pressure port T fitting and the "open" port on that would have likely fed the oil pressure gauge line. I can't say from what I'm seeing in your as received picture how the oil feed to the head was at that point.
Just my $.02 worth, but with your engine assembled like it is currently, BEFORE you attempt a full start as it sits, I would suggest you pull the distributor and valve cover, then use a drill with a flat blade style rod to prime/pressurize the oiling system and confirm if you have oil coming up to and dribbling out of the valve rockers.
If no oil present at the rockers doing this, you have to presume that the oil passage in the block to the rocker feed is blocked and you must either correct that internally or add the bypass external oil supply line (like on my engine). If you don't, your top end is going to self destruct from lack of lubrication. frown
~ Dan
Thank you Dan- You are giving me a lot to think about, and all good advice! It sounds like my best bet would be the internal oil line behind the valve pushrod cover....? If I did that it would be out of sight and relatively easy to plumb in. (I attached another marked-up pic) Or do you think it would be best to use the outside port in the head?
This engine came from a running truck, but I can't figure out how the internals were in such good shape. I did replace the valves, but the rocker shaft etc. measured in tolerance etc..
Thanks again to everyone for the information!
Dave
1956 Thriftmaster
1954 Blue Flame
1962 Thriftmaster
Dave - Being that your 235 is a '56 block, I think after checking the 1955 2nd Series and 1956 Supplement Shop manuals (hoping not famous last words - dang ) that the oil pathway for your block going from the rear cam bearing journal, through that interior oil line to the upper feed port (both currently blocked by plugs) should feed through the existing block oil galley up to the head port hole that the rocker oiler is inserted into. That is offset from the head bolt location, and I think (again) that the oil pathway doesn't need to have the drilled head bolt like the '57 and later engines came with. See the attached oil path diagram from the '55 Shop manual.
Once again, to prove this theory, you'll need to install that behind the cover oil feed line, then use the previously mentioned drill setup to pressurize the oil system and check for oil flow to the rockers.
Hope this is helpful. wink
~ Dan
