0 members (), 68 guests, and 3 robots.
Topics128,244
Posts1,057,714
Members48,474
Page 3 of 3 1 2 3
7
7 Offline
Man, sorry to hear that. If it were mine, I would leave the engine in the truck and pull the heads. The 355 that I built years ago was drinking oil at an alarming rate, when I was farming out the machine work originally, I took the heads to a shop that was recommended, bronze guides, 3 angle grind, umbrella seals. I pulled those heads and replaced them with another set of cast iron medium valve units but had another machine shop do the head work. Along with the head swap and pulling the big block oil pump and putting in a small block normal capacity pump, the oil consumption problem disappeared.
I considered leaving the engine in the truck but working over the fenders to remove much, especially heavy things like the heads doesn't sound like a plan. I may take the carb and intake off to check for oil being sucked in from the valley (wishful thinking, I know) but that would be the limit I think.
1949/50 3600 Project
Follow in Project Journals
If you still have the 235 , get it rebuilt. At our age , who cares about how fast we get there. Most important ...how it sounds.
Making a bunch of noise but still cannot go faster than a hyndai, seems silly.
Only thing I pass out here are tractors and amish buggies.
Or buy a crate 350 and sell the 383. Quicker that way.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I don't have the 235.
I built the 383 and need to understand what I did wrong so no plans to replace it and I am not in any hurry.
RLB Offline
Sorry you’ve got to deal with pulling the engine but I’m with you. I’d want to know what went wrong.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
Page 3 of 3 1 2 3
