4 members (Otto Skorzeny, klhansen, ShopRag, Pinetree), 99 guests, and 5 robots.
Topics128,263
Posts1,058,133
Members48,482
Page 2 of 2 1 2
Glad we could help you push the "easy button" ! thumbs_up
Let us know how the vendors service is and when you get to installing it please and thanks. wink
~ Dan
1951 Chevy 3 window 3100
Another fix for vapour lock is to install a vapour seperator fuel filter. These were installed on the last of the AMC carbureted model. The filters have one inlet port and two outlet ports, one obviously goes to the carb, the other port returns the fuel to tank. This requires installing a return line to the fuel tank.
The concept is, there always fuel movement.
This has worked great for me.
The part number is Baldwin BF886
O Online: Content
Where do you install the filter? Between pump and carb?
Hastings / Baldwin GF19
https://www.rockauto.com/en/moreinfo.php?pk=5475960&cc=0&pt=6200&jsn=538
1950 Chevrolet 3100 (Ol' Roy)
Yes, between the fuel pump and carb. I used steel brake line for the return to tank line.
Dave
P Online: Content
A report on the Spectra tank purchased from Autoplicity...
Autoplicity shipped the tank the next day as promised. Between having the lowest price and good service, I'd use them again. The Spectra tank appears to be well made. My only reservation is that the tank was poorly packaged by Spectra and the filler neck vent pipe was sticking out through the side of the cardboard when delivered. No damage to the tank, but Spectra should add extra packaging to prevent the tank from sliding around in the box during handling. Even though I have a tank cleaning/coating kit that I purchased months ago, that really is a warm weather project not really suited for November in Colorado. I'm glad that you guys turned me on to this new tank. Thanks again!
Dave
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
O Online: Content
Your truck has a fuel pickup tube that goes in from the top, right? It doesn't flow out of the bottom via gravity like the earlier tanks, right?
P Online: Content
Yes, the pick up tube/sending unit attaches at the top.
Page 2 of 2 1 2
