| | | Forums66 Topics128,237 Posts1,057,636 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 564 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 564 | Looking for a 66 era overdrive saginaw 3 speed with the 7 bolt sidecover. I would also be interested in just the borg warner OD rear section to add to a normal saginaw 3 speed. I already have the governor and solenoid. Just need a whole trans or the hard parts to convert one. Thank you. | | | | | Joined: Mar 2007 Posts: 3,467 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,467 | You may want to reach out to Cosmo, he is pretty knowledgeable on these and has supplied an few in the past.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Sep 2009 Posts: 6,072 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,072 | I did some web snooping and found this ad for a Saginaw 3 speed overdrive in the Tri Five Marketplace ads. You'll have to join up to be able to contact the seller as I couldn't find any direct contact info in the ad.  Preliminary search of FB Marketplace done, but only scratched the surface on that look. Will try to see if I can locate anything else with a deeper look.  Best of luck with your search!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2020 Posts: 1,984 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,984 | I got a 4 bolt side cover I just pulled that I will never use. SM-319
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Jul 2019 Posts: 564 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 564 | I joined the group but cant PM or reply on the for sale section for 30 days. | | | | | Joined: Jul 2019 Posts: 564 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 564 | I got a 4 bolt side cover I just pulled that I will never use. SM-319 I have one in truck currently and a spare one for parts but im sick of the old 3 speeds popping out of 3rd. Seems like anytime i use them they are a annoying problem. | | | | | Joined: Sep 2009 Posts: 6,072 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,072 | Barnfind49 - You're at full 'Bolter status so free to PM "Cosmo" or any other unmoderated 'Bolter.  Have at it sir as there's no 30 day wait period.
| | | | | Joined: Jul 2019 Posts: 564 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 564 | Barnfind49 - You're at full 'Bolter status so free to PM "Cosmo" or any other unmoderated 'Bolter.  Have at it sir as there's no 30 day wait period.  I meant the tri-five forum listed above not here hahaha. | | | | | Joined: Oct 2019 Posts: 447 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 447 | | | | | | Joined: Jul 2019 Posts: 564 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 564 | That one in the pic above is a OD trans but its not GM. Possibly a ford/merc trans looking at the front hole spacing. | | | | | Joined: Sep 2009 Posts: 6,072 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,072 | [quote=Gdads51]I meant the tri-five forum listed above not here hahaha. Ah, the little light bulb overhead just illuminated - LOL!  The good news is there hasn't been a lot of interest in the ad thread there, so a good possibility it could still be available after the "pause". I'm still looking and will post other leads as I can.
