4 members (Otto Skorzeny, tclederman, Gray_Ghost, DBJ71SuperCustom), 88 guests, and 4 robots.
Topics128,237
Posts1,057,636
Members48,473
Page 10 of 10 1 2 … 8 9 10
O Online: Content
Cylinders can be bored over or sleeved. Don't condemn the block, yet.
1950 Chevrolet 3100 (Ol' Roy)
I know that you are looking for issues in the cylinder bores related to the excessive exhaust smoke but I believe that you indicated cylinders #1 and #2 that you recently inspected with the bore scope had no indication of being the source of the smoke (clean plugs and decent compression). While the pictured piston defects are concerning and may add to your list of concerns for the engine try not to go down every rabbit hole you find or your driive yourself crazy. If your goal is to have a resonable looking and driving truck that will get used like most of these trucks are (a few thousand miles a year at most) without the cost of rebuilding the engine step back and review what you know, what else you need to know, and how best to obtain the information.
Having a lot of air pushing out of the carburetor when doing a leak down test would tend to indicate the intake valves were open, not just leaking past the valve/seat interface.
A good running replacement engine that you can install and achieve your goal without spending money on a rebuild is like winnning the lottery, possible but odds are not good.
1949/50 3600 Project
Follow in Project Journals
G Online: Content
OK, I'll secure from GQ...for now. In the meantime, stupid questions: if one of the possibilities is oil leaking past bad valve guides or seals, what will happen if oil/diesel makes its way into the cylinder? Will I cause even more damage? Is there a downside to filling each cylinder with the Berryman and allowing it to drain into the pan before I drain it and then remove it to clear out the sludge? Am I overthinking the sludge clogging up oil passages and should I go straight to the diesel flush (assuming that I won't cause any damage from diesel entering the cylinders)? Then there's the concern of running the engine with pistons that have chunks missing. I've assumed that is a bad thing. Am I wrong? A gentle reminder: I have no experience working on engines! I am truly at everyone's mercy on this!!!
Mike
1953 3100
The Gray Ghost
My Project journal
I don’t think those are pieces missing from the pistons .Pistons have a mark on them to show the direction they are to be installed if I am correct .Do those marks happen to be pointing to the front of the engine .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Here is what chev of the 40,s show on there pistons they sell.
"The Journey"
Follow in the DITY
Those pics of the pistons don't look serious. Those notches may just be indicating the front of the piston for installing. That's a pretty common method that the manufacturers use. See pic.
So you should come down off that ledge as well. wink
[on edit]Looks like Kevinski squeaked in just before me with a pic.
O Online: Content
Prior to multi-viscosity oils, it was common for crankcase oil to be diluted with kerosene in the winter time to thin it out. My 1939 Packard shop manual specifically says to dilute the 30 weight oil with 10% kerosene when temperatures are expected to be below 45 or so. It may even say that in the AD Chevy shop manual. Kerosene isn't as oily as diesel and it didn't harm the engine.
My dad worked at a Howard Johnson's service station as a young man and one of the regular services offered was a diesel engine flush similar to Jerry's description.
Diesel will act as a solvent to remove built up crud throughout the crankcase and will leave an oily film, unlike kerosene. By overfilling the crankcase with the two extra quarts, the crankshaft will churn the oil/diesel mix like butter and splash it all over, dissolving the crud.
Jerry and others will probably comment on the missing chunks of pistons but the missing pieces are long gone. Whatever damage they may have done is already done. The pieces probably got expelled into the exhaust system.
Stick a bendy magnet down the plug holes and see if you can fish anything out if you're worried.
G Online: Content
Ok, I'm down off the ledge! The notch is a fascinating bit of info! So I guess the next question is do I need to drop the pan and clean it or just get the diesel and send it?
Mike
1953 3100
The Gray Ghost
My Project journal
O Online: Content
If you are going to do an engine flush, definitely remove the pan and clean out all the sludge, first. No need to loosen up the crud that's already congealed at the bottom of the pan. Clean out the sludge in the oil filter canister, too. Then fill it up with the oil and diesel, etc.
Glad to hear you are back off the ledge. Doing things like the engine flush are great things to do without tearing things too far apart and without spending a bunch of cash with an unknown outcome.
I have found this forum to have a great bunch of people willing to help out so keep us informed and we will continue to help you move forward.
AD Addict & Tinkerer
I’m going to disagree that those marks are piston locator marks. I blew up the first picture and you can clearly see fresh shinny metal on the piston and displaced metal on the block.
I would pull the head to see what is really going on. It only the cost of a few gaskets and few hours of time.
Damaged piston
Phil
Project Journals
Stovebolt Gallery Forum
Crusty Old Sarge
Crusty Old Sarge
I would agree with Phil. The location notch is machined into the piston, that area looks as if it was damaged by some foreign material.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I am not sure about the notch but the blown up picture of the cylidner bore looks pretty smooth (no cross hatch) so I suspect that at a minimum the bores will need to be flex honed and new piston rings will be required. You won't know if the bores can be flex honed or need to be bored oversize without measuring the bores for wear.
Running the cleaning procedure before you tear it down shouldn't hurt anything and may provide a stop gap solution to provide you time to accumulate the funds required to have the engine rebuilt.
G Online: Content
Hey Everybody,
I moved the truck today and have it pointed out the garage door. I did this so I can work on the engine and reach everything easily. I've decided that I'll potentially learn the most by removing the cylinder head. I can always do the oil flush later. I'll post updates as I have them.
Tips, things to avoid or things to definitely do would be appreciated!
Mike
1953 3100
The Gray Ghost
My Project journal
Keep all lifters and push rods in the same order as they were removed. Failure to do so will result in excessive cam wear and eventually failure.
I used individual sandwich bags for the lifters and a piece of cardboard (I punched holes with a screwdriver), to keep the push rods in order.
Phil
Project Journals
G Online: Content
Thanks, Phil. Will do!
Mike
1953 3100
The Gray Ghost
My Project journal
G Online: Content
Hey Everybody,
Cylinder head removal update: I had to remove the upper radiator shroud so that I could reach the petcock on the radiator. I might have been able to reach it from beneath, but I felt like coming down from above was the least likely way to spill a bunch of coolant. Anyway, it's out and the radiator is now drained. Or at least partially drained. I only got about 3/4 of a jug worth out before it stopped draining. I'm wondering if the excessive "smoking" might not have been some coolant as well as oil. Time will tell! Both the intake and exhaust manifolds have been removed. I did remove the carburetor prior to removing the manifolds. I used the borescope camera to get a peek into the cylinder head. Attached is a pic showing the Siamese exhaust ports for #4 and #5. It's pretty obvious #4 was working as designed and #5 wasn't. I also looked into the exhaust port for #6 and it was as bad as #5. All this information does is confirm that #5 and #6 were malfunctioning. It does not tell me if the problem is in the head or the rings, but at least it gives me a place to start looking. Second pic is the current state of the engine.
Tomorrow, I'll disconnect the thermostat housing, remove the spark plugs and then disassemble the rocker assembly from the head and then...remove the head.
Man o man, am I in uncharted territory! Let's hope I don't bollix it up! Last chance for helpful suggestions!
Mike
1953 3100
The Gray Ghost
My Project journal
The head is heavy. Get some help to remove it or if you have an engine hoist, you can use the holes from the removed rocker assembly to bolt on some lifting lugs (or chain) and lift from there.
Phil
Project Journals
What Phil said. Even with the engine on a stand where you can get up close to help with lifting, I used a hoist to remove and install it. I would never try to manhandle a head out of the engine compartment, even with help.
G Online: Content
Hey Everybody,
Quick cylinder head removal update. I mentioned last update that when draining the coolant, I only got 1/2 a coolant jug worth. I was concerned that the head would still have coolant in it and make a giant mess when I unbolted it. So I unscrewed the temperature sending unit and could see liquid right there. So...I needed to find a way to drain more. I went to the block drain at the rear of the block, knowing that it was likely blocked with rust. It was. I did manage to get it flowing by using a small pick. It started slowly but picked up quickly. Ultimately, it worked. Looking into the temperature sensor hole, it was completely drained. I took another 1 1/2 gallons through that port. I know that there is still some coolant in the block, but I think it's out of the head. After that, I took the plugs out, the coil off and the lifter gallery cover removed. I've attached 2 pics of the gallery. Mostly nothing of note, but I did notice that in #5 and #6 the lifter cups are full of oil. The others are mostly not filled. I don't know if it means anything, but I did notice. Anyway, the head should come off next time in the garage. Updates then.
Mike
1953 3100
The Gray Ghost
My Project journal
G Online: Content
Hey Everybody,
It's apart! Multiple pics attached. Biggest bit of info that I could see is everything on the passenger side is wet with coolant. Also, dead center of the driver side is an obvious coolant blowout. There, it actually ran down the outside of the block. Based on the wetness and condition of the valves, I'm wondering if #5 and #6 were really firing or not. I forgot to snap some pics of the valves, and will do thst later.
I wasn't able to get the lifters out of their holes. It's like suction held them in place.
Pretty decent ridge ring at the top of each cylinder. I couldn't find any markings on a piston to indicate an oversized one. I think this might be an honest, original and very tired engine.
Ok, folks. NOW is the time to speak up! Thoughts? Next steps?!?
Mike
1953 3100
The Gray Ghost
My Project journal
FROM MODERATOR:This question would be better posted in the engine forum. You’ll get more responses there as many of our experts (sad to say), don’t follow the Project Journal forum.
Phil
Project Journals
G Online: Content
Ok, Companion piece posted in the engine forum.
Mike
1953 3100
The Gray Ghost
My Project journal
Moderated by  Phak1
