| | | Forums66 Topics128,236 Posts1,057,629 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 1,998 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,998 | Man, sorry to hear that. If it were mine, I would leave the engine in the truck and pull the heads. The 355 that I built years ago was drinking oil at an alarming rate, when I was farming out the machine work originally, I took the heads to a shop that was recommended, bronze guides, 3 angle grind, umbrella seals. I pulled those heads and replaced them with another set of cast iron medium valve units but had another machine shop do the head work. Along with the head swap and pulling the big block oil pump and putting in a small block normal capacity pump, the oil consumption problem disappeared.
| | | | | Joined: Nov 2021 Posts: 1,415 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,415 | I considered leaving the engine in the truck but working over the fenders to remove much, especially heavy things like the heads doesn't sound like a plan. I may take the carb and intake off to check for oil being sucked in from the valley (wishful thinking, I know) but that would be the limit I think. | | | | | Joined: Dec 2020 Posts: 1,984 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,984 | If you still have the 235 , get it rebuilt. At our age , who cares about how fast we get there. Most important ...how it sounds. Making a bunch of noise but still cannot go faster than a hyndai, seems silly. Only thing I pass out here are tractors and amish buggies.
Or buy a crate 350 and sell the 383. Quicker that way.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Nov 2021 Posts: 1,415 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,415 | I don't have the 235.
I built the 383 and need to understand what I did wrong so no plans to replace it and I am not in any hurry. | | |
