3 members (Cosmo, 1955 1 Series, Wayne67vert), 145 guests, and 2 robots.
Topics128,232
Posts1,057,569
Members48,473
#1614174 10/28/2026 8:19 PM
So, I am familiar with a condensor and what it does in a distributor.
This looks like a condenser but is it? How/what does it do.
I assume it's to reduce electrical interference for a radio.
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
Rock49 #1614179 10/28/2026 9:48 PM
Correct. Condensers were used to reduce radio noise coming from the generator.
Rock49 #1614186 10/28/2026 11:07 PM
Moderator, Electrical Bay
But you can't use an ignition condenser there...they're different with higher voltage to act as a shock absorber for the coil output without failing. The generator condenser (really just a capacitor) generally speaking had a uF value of between .1 and .5uF and generally were rated for around 50v all the way up to 1000 volts. It depended on the vehicle, etc and some included a lot of overkill. But if you have an AM radio (this all predated widespread use of FM), I'd say you would be fine with .5uF and 50volts. You would hear the whining from the brushes/armature and it would sort of mimic the sound of a siren in the background as rpms increased/decreased.
~ Jon
Rock49 #1614197 10/29/2026 1:02 AM
Klhansen and Jon G.
Thank you.
I have seen these in various places under the hood of older cars in the past and was always curious. Would one have been necessary on early FM radios or is it just an AM thing? .
Chris
Rock49 aka C-Rodg
work in progress
1956 Chevy 3100
261 engine
