I have a 1956 "Goodwrench" replacement engine (it has no serial number markings so I am assuming this) that did not have an oil line from the rear area of the engine to the rocker shaft inside the pushrod galley. Has anyone ever seen this before? I believe it is plugged in the rear. I have it all put together now and I just realized I never saw it during disassembly.... I was watching a YouTube video of someone that found theirs to be clogged, and that was when I realized I may have missed something! Thanks in advance!
55 GMC 3100 2nd Series 71 GMC 1500 Super Custom 1956 Thriftmaster 1954 Blue Flame 1962 Thriftmaster
I have a similar situation with a later 261. The block was cast in 1962 and no serial number indicating it was a replacement block, but had a 1957 261 head on it. When I got it, it had an external oil supply line feeding off a T-fitting on the oil pressure gauge port that wrapped around the exterior rear of the engine and back up the passenger side and then feed into a central oil port in the side of the head just below the valve cover.
Removing the push rod side cover, I also found that the internal ports for the oil feed line normally found under the cover where blocked with threaded plugs.
Turns out that the later block doesn't have the same cast in block oil feed channel to match the earlier '57 head, preventing oil from going to the rockers through the block and a "drilled" head bolt that would normally provide the lubricant path to the rockers in the earlier engines. So for me, that external line is essential to providing lubricant to the rockers and must stay.
It could be your engine is the same, or it's possible that your engine, like many of that period ended up with clogged internal feed path. The Chevy work around fix for that was to install an external oil supply feed like used on mine, plugging those internal ports, and restoring oil supply to the rockers.
I think you made need to confirm what you have for both the block and head to try and figure out what path to follow for getting oil to the rockers. Let us see some casting numbers an date codes from both the block and the head so we can offer more help.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Thanks for the info! The holes in the pushrod galley are plugged with square-head threaded plugs, so I could not have forgotten to put the line back. (see attached) I have an 848 head, and the engine casting is dated 1956, but no serial number stampings. The oil line on the drivers side has a tee, but I assumed the tee line is for an oil pressure gage, but I never saw the truck this came out of. I am really perplexed on what I should do from here. I did not have a line going around the back like yours, so I can't under stand how the oil gets to the valve train! It's great to have a site like this and I really appreciate your help!
From what I can see of your pictures, you have an existing "T" fitting at the oil pressure gauge port. One of those outlets would have fed the oil pressure gauge and the other the external line to the rockers, like on my 261 if I'm presuming correctly.
Before I go down the "unfortunately" road, did the center head bolt on the passenger side on your engine have a drilled hole up through the bottom and out the side of the threads? Here's a 'Bolter "Pre '68 Dave" Blog Post on the rocker oiling system subject and the "drilled" head bolt info that can better describe this than I can. No need to reinvent the wheel me thinks.
It's most likely (IMHO based on what's known so far) that with your oil ports behind the push rod cover plugged the same as mine, it's likely you will need to run the external oil supply line to feed oil to your rockers.
The only way I can think of starting to checking things further requires you to remove the head and look to see if the oil passage mentioned in Dave's post is blocked, plus look to see how the oiler that feeds from the head to the rockers is set up.
