... Shocks are not so great and at some point I may change to modern tube shocks if possible. Radial tires are a huge difference from bias ply tires. Truck is tracking nicely down the road.
John, when you hit a rough surface or pot hole, does your steering wheel jerk all over the place and you have trouble staying in a straight line?
If not, I suspect your thoughts about the lever action shocks are misplaced. These trucks have very stiff springs. The ride is pretty hard over less than smooth roads. Tube shocks won't change that.
When Ol' Roy came to me, the shocks were shot. None of them would expand on their own when compressed. A couple had leaks and no fluid in them. The steering wheel would practically jerk out of my hand when hitting moderately rough roads.
With proper sized radial tires and working shocks, the truck stays straight on course with no jerky steering wheel, but the ride is still a lot stiffer than you'd be used to in a modern car.
If your truck tracks straight over rough surfaces and you don't have to fight the steering wheel, your lever action shocks are working properly and I doubt tube shocks will give you the improvement you might expect.
1950 Chevrolet 3100 (Ol' Roy)
Truck drives straight and steering is easy to handle when hitting bumps or pot holes. Well, I guess I'll have to get use to all the little bumps and not worry so much.
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engine Here We Go Follow in his DITY Bay
Good for you John, 100 miles is admirable. Part of the fun of driving an old truck, or any old vehicle for that matter, is to pay attention to the way it drives and how far we have come with the newer vehicles and all the electronic nannies that are built into them. My wife and I kids think I’m crazy, but I learned to drive in a ‘51 3100 and the first thing I do is turn off the nannies before I leave the yard. Enjoy the bumps and rattles and the inevitable wandering steering. You’re in 1946.
Welcome to my world. I'm a fish out of water when driving a modern car.
BTW - Thanks for a perfect picture of your truck being used as a truck!
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Still adding miles and getting "thumbs up" from other drivers and lots of conversations at gas stations and Home Depot parking lot. I'm getting better at down shifting from 4th to 3rd without grinding gears. I'm learning that I need to plan ahead for stopping as the brakes take a lot of pedal force to stop in a hurry. I took a drive to Harbor Freight yesterday and noticed I didn't have my phone. Probably left it in the garage? Nope. As you can see in the picture, I left it on my front fender and it dropped off a couple miles from home. When I got home, I called my number (I still have a land line) and a nice lady answered and said her husband found it in the road. No damage thanks to my Otter Box. I feel so lucky. And yes, I gave her a tip!
That’s funny! Those darn round fenders. Glad your phone survived. One day on my way to Fleet Farm I was looking for my phone in the cab of my newer truck. Couldn’t find it and thinking it through where it may be was on my rear bumper, 5 miles from home on a busy 4 lane highway I pulled over and looked on the flat area of bumper. There it was.
1946 Chevy Truck 216 1/2 ton "Tales from a weekend mechanic" Follow in the DITY
I once left my cell phone sitting on the bed rail of my pickup truck. I drove around the block and when I came to a traffic light and stopped I heard it rattle onto the ground but was still rolling to a stop. Of course when it hit the ground it bounced right into the track of the truck and I ran over it with the back tire.
It was a flip phone so it wasn't damaged too badly but the battery was bent and look like a melted piece of chocolate in a silver wrapper. I straightened it out as best I could and cram the whole thing back together and use that phone for a number of years after that
Quick run out and get yourself a lottery ticket before your luck runs out.😀 I think the big guy was looking down and sent your Guardian Angel to find another mortal to find and save your phone from a crushing event.
Nice to hear you got it back in working order.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWB In the Gallery My Flicker Photos!
My truck was sitting for a week and the cardboard under the transmission showed there was a slow leak from the drain plug. So, I slipped under and gave the plug a little more tightening. I'll put some new cardboard down to see if that helped.
I keep a large supply of big sheets of cardboard for all these leaking vehicles. Some people have fancy ceramic paint or tile floors in their garages. Mine are covered in cardboard!
I kept the cardboard from my TV purchase a couple years ago. It has been easy to figure out where the little drops are coming from. Left rear - a few drops of brake fluid. Both fronts - have small amounts of hydraulic fluid from the lever shocks. (That was one reason I was thinking about changing to modern tube shocks.) But, the cardboard definitely helps.
All these little leaks made me realize why there was so much gunk on everything when I started on this project. 🙂
It's self preservation. These leaky trucks coat their entire undersides with grease and oil over the years. This keeps them from rusting away.
Not a bad idea with the cardboard, although my garage floor has a few leak spots that are too late to absorb. Wood shavings do a great job if the leak is fresh. Rub them around, sweep them up, floor is almost as good as new.
Took my longest drive (so far) down to Payson, UT to pick up some more Sweet Corn. It was about 36 miles round trip with no issues. Then, I did my first valve adjustments. I have about 270 miles on the truck now. Thinking about changing the engine oil and the rear gear oil at some point. I should probably wait until 500 miles?
My first car show in downtown Provo, Utah. Provo has this small car show for vehicles older than 1990, so I decided to park my ride for a few hours. I got to talk with lots of people. Many were happy I kept the straight six.
John - The truck is looking great and it looks like you had a really big turn-out at the show!
Thanks for sharing!
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
Wow - over 400 miles on the truck now and lots of thumbs up and horn honks. I also took time to re-mount my fog lights. When I first mounted them directly to the vintage brackets, they would some how end up leaning back and pointed upwards after each drive. I added a piece of flat stock and they feel more secure now.
It's been raining here the last couple days, so I decided to get my storage box installed into the bed and have a place to store my bottle jack and a few tools. I'll probably add some carpet or maybe a rubber mat. I did add some little rubber feet that line up with the bed strips. It will keep the box raised a little above the bed and maybe help to keep things dry under there. I'm going to use two of the bed strips bolts on the back side to hold it down, but I'll need to drill a couple holes on the front side.
Getting started on one of my winter projects, but Ficken Wiper Repair does not have the parts to rebuild my model. 🙁 Not sure I can fix this myself, so I might need to look at electric options. I've not liked electric because the ones I have seen stick out and you cannot use the original covers to help hide the motor. I'm going to clean-up everything and see if I can rebuild it myself. I can try to cut a new gasket, but not sure about the paddle part.
Ficken only rebuilds units. They do not sell kits so you can do it yourself.
I don't even bother with the vacuum wipers on my vehicles.
My opinion, trying to rebuild a vacuum wiper motor by yourself is an exercise in futility. Gaskets are one thing (and I've seen them for sale on eBay), but reconditioning the paddle is a disaster waiting to happen. Kudos to Rob Ficken that he's able to do that. Maybe he has enough of a stash of part that he's got replacement paddles. Or maybe he has mastered how to recondition them.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
I really like my vacuum wiper. We`ve had alot of thick fog lately and I can set the wipers to a slow crawl that does better than a delay or on/off. Too many bugs around to keep rain x on my windshield.
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
