3 members (KEVINSKI, Cosmo, ShopRag), 91 guests, and 9 robots.
Topics128,187
Posts1,057,212
Members48,465
Moderated
Moderated
Does anyone have info on ac9803 dual action fuel pump vacuum line installation? Can't find any information. There are two threaded ports and one port with no threads on the vacuum portion of pump.
Formally known as tttt8
I have the vacuum lines that came off a 58 235 with fuel/vac pump. The two threaded ports get the lines that are routed alongside the fuel and distributor vacuum lines around the front of the valve cover. I'm not sure at this point which of the threaded ports is IN and which is OUT, but that wouldn't be hard to figure out by moving the lever with a thumb over one port. My pump is an AC4080 with glass fuel bowl. I don't recall seeing a non-threaded port on the vacuum section, but could go check. If you'd like a photo of my pump, I could do that as well.
Here's a couple of pictures from the 1947-54 Chevy FAM with the diagram of the RPO 340 Fuel & Vacuum Pump instructions. Overall and close up. The pictured pump in this diagram is a slightly different design from your AC 9803, but the number of ports and purposes remain the same.
BTW - The unthreaded hole in the vacuum pump housing is a blind (closed) hole in the casting which isn't used in your application.
~ Dan
1951 Chevy 3 window 3100
Here's some pics of my AC4080 pump. There's no unthreaded port on it, but there are a couple of small vent holes between the two diaphragms.
Overall view showing the two vacuum line ports
Pic showing small vent holes
K Online: Content
Check out Desert rat fabrication on you tube shows how the vacuum works lines hook up .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
