0 members (), 132 guests, and 1 robot.
Topics128,285
Posts1,058,276
Members48,483
#1613608 10/19/2026 3:05 PM
Hello,
My 1953 Chev 1/2 ton has an aftermarket 80 psi oil pressure gauge dangling under the dash (I know, I need to properly secure the darn thing). The gauge is connected to the engine with a 1/8 plastic pressure line and I simply hate this setup.
The dash still has the factory gauge to 30 psi. Is it possible to use 1/8" flexible copper tubing to connect the aftermarket and perhaps 'Y' the old gauge in with it? Or would the higher pressure damage the factory gauge?
Oil Gauge
JoergK.
1948 GMC Model 9434 Frame rebuild
1953 Chevrolet 1314 1/2 ton rebuild
Follow along in the DITY Bay
Yes, you can replace the pressure line with copper and a T to run both gauges at the same time. But then you'd have to deal with Segal's Law.
What pressure does the add-on gauge show at highway speeds?
Does your '53 still have a spash-oiled 216 engine or a full pressure 235? Big difference.
If the original gauge works (which it probably does), I'd put the aftermarket one under the hood or in some hidden place, or just remove it altogether.
I just took this picture of hour or so ago (idling in the driveway, by the way). The temperature gauge and the oil pressure gauge have both been checked against modern instruments and they are both perfectly accurate. And have never been rebuilt.
1950 Chevrolet 3100 (Ol' Roy)
Joerg - Is it possible that the original gauge wasn't working, which required the add-on gauge so you could keep track of oil pressure? My Grandpa's truck had something similar, where he left the old non-working gauge in the dash assembly and just added another to do the job. It was done back in the early 70's IIRC, when he replaced the original 216 with a 235 car engine. He didn't care about it looking original, just functional.
Bill Hanlon asked a good question on what engine you're running as that may affect what gauge you use. Can you let us know what engine you have and if you know why the add on gauge is there???
Once we know a bit more on these details folks can offer more/better suggestions. wink
~ Dan
1951 Chevy 3 window 3100
I have no info what was done to the engine. I was told it was rebuild in a high school tech. class and the teacher is a car mechanic.
The body rebuild is documented by parts list that got bought, but the engine is without history, nicely painted!
No oil filter added and the gauges shows 43psi cold, 38-40 warm.
JoergK.
Joerg - That steady high oil pressure will surely keep the original 0-30psi gauge "pegged", if it's still functional. If you want to do away with the extra dangling oil pressure gauge, you could order a replacement stock style gauge with a 0-60psi range from many of our vendors.
I recently did just that to go along with my 261 upgrade. I purchased my gauge from Jim Carter - 1949-1953 NOS (GM Original New Old ...e Rebuilt Chevrolet and GMC Pickup Truck, and it's a perfect replacement in the original cluster. Unfortunately it looks like they are now out of stock. frown
You might try sourcing one from Bill's Truck Shop. See the item marked in red in the attached screenshot from their catalog. It does indicate it fits 50-53 models, but the color scheme shown in your picture above matches the one indicated.
~ Dan
Dan - you are the man (beside many other of you🧒). As always, time is not the issue. I can wait!
JoergK.
Moderated by  ndkid275, Phak1
