| | | Forums66 Topics128,203 Posts1,057,414 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2019 Posts: 87 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 87 | I am trying to get a 235 engine (casting #3769716) I bought from a n engine shop in MN that has turned out to be Chinese parts and a spray can. I want to use a stock looking Delco distributor with a pertronics upgrade. Which distributor # would have GM put on this block? Where is the best source for this distributor? | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Hi Ron...first of all please let us try to disabuse you of wanting a Pertronix equipped distributor. It may not be an upgrade as much as a source of accelerating hatred. The casting number for your engine sounds like a later (1958 and up) model 235. Others may have ideas. Any of the 235 distributors from that time period will work or there are HEI alternatives. I have one of the offshore distributors made for the 230/250/292 I modified and showed how to modify here on the forum. It has been working since 1997 without trouble. It doesn't look like original but one of the few "original looking" HEI distributors was Tom Langdon's Mini-HEI and he hasn't been making them for a while now. Please avoid Pertronix though. As Jerry (HotRodLincoln) says there are two types of those: the ones that have failed and the ones that are fixing to fail.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jul 2019 Posts: 87 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 87 | Thanks...I am trying to keep the "stock" look. What would you recommend to meet my goal? | | | | | Joined: Feb 2004 Posts: 29,887 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,887 | If you're willing to use a conventional points/condenser setup, the original equipment distributor is hard to beat. Untold millions of them worked for 50+ years in daily driver cars and trucks with only routine tune-ups. It's also possible to convert the stock distributor housing to use components from a General Motors HEI system and keep the "original" look by placing the HEI module in a finned aluminum heat sink, mounted on the firewall or even under the dash.
Send me a private message and I can give you more details on that conversion.
| | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | Well, Ron you could look for one of Tom Langdon's distributors (they show up for sale here occasionally) or you could as Jerry said get a stock distributor and use points, condenser, coil. Jerry (and I) have had ideas about how to convert a stock distributor into a unit that either fires a single coil or fires 6 coils (each attached to a plug). Tom Langdon had a very good idea with his unit (it was adapted from the Chevy V6 engines from around 1980~82 as I recall) and it worked very well but to be honest there was quite a bit of machining necessary to make them.
| | | | | Joined: Oct 2021 Posts: 6,969 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,969 | This guy will convert any original dizzy to an HEI setup. He's been around for decades and has a very good reputation in the antique Cadillac community. As he rightly points out, "Pertronix" (although not named explicitly) is not a High Energy Ignition system despite what they try to tell you. DAVE's small-body HEIs Converts your original points style distributor to HEI system 24 Buffalo Lane Yerington, Nevada, 89447 775- 722-3294 [email protected]http://www.davessmallbodyheis.com/
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jul 2019 Posts: 87 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 87 | This motor is going in a '41 pickup with all of the stock ignition for the 216. What I hope to find is a reliable new or rebuilt Delco type distributor. | | | | | Joined: Feb 2004 Posts: 29,887 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,887 | There is nothing particularly mysterious about "HEI" (High Energy Ignition). It's simply an ignition coil capable of producing open circuit voltage above 50 KV- - - - -far above what a conventional point type ignition system can develop due to the limited current capacity of conventional ignition points. The 50 KV capacity was mandated by the "Clean Air Act" of 1968- - - -which required engines to go "emissions legal" for at least 50 K miles without the ignition or fuel systems being serviced. That problem is solved by using a high primary current coil triggered by solid state electronics instead of points. Since clean, properly gapped spark plugs usually fire reliably at less than 10 KV, "HEI" is really just for people who are too lazy to do regular tuneups. Even full throttle acceleration requires less than 20 KV at the spark plugs.
If you're planning on running the original 6V electrical system, your options are going to be VERY limited when trying to use electronic ignition. Jerry
| | | | | Joined: Jul 2019 Posts: 87 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 87 | | | | | | Joined: Feb 2005 Posts: 1,688 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,688 | Have you checked out Deve's Technical Network? There is an article about a High Energy Ignition on your stock dizzy. LINK
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Feb 2004 Posts: 29,887 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,887 | Be careful about linking that site- - - - -lots of sketchy information at times. Jerry
| | | | | Joined: Feb 2005 Posts: 1,688 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,688 | Be careful about linking that site- - - - -lots of sketchy information at times. Jerry Sorry about that Jerry. I did not know. 😕
| | | | | Joined: Jan 2022 Posts: 2,503 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,503 | Jerry says it may be "sketchy at times", but I've been running a Deve HEI in my '52 GMC (uses the same distributor as a Chevy 6) for since 2015 with no problems. The only thing I changed was to hide the HEI module inside my unused voltage regulator. Details HERE.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Dec 2020 Posts: 282 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 282 | I put one of Deve’s HEI systems in my original distributor. It worked great for about a year. Then I went though five HEI modules in just a few months. I went back to points and condenser from NAPA and it has ran great for three years. If you want a DEVE’s system you’re welcome to mine. I won’t put it back in.
1947 3600 Chevy
