Allow me to move into the paint department with my GMC 48 rebuilding job to ask some general questions.
I am use to learning new things, doing it for 72 years and I am not tired of learning.
Several questions bug & bother me:
A) getting rust, old paint off is easiest done with blasting. The division comes on 'for what item' ? So, sandblasting with fine sand for the frame and powder coat that black? My son has it done for the frame of his 1986 Buick station wagon and he seems to be happy with it, but that was done by a sand blasting shop since our booth can't handle the full frame.
B) How about other pieces? We can powder coat up to 8'x4'x3' pieces, so would it make sense to powder coat as much as possible?
C) Can one powder coat all metal pieces or is there a true advantage by going with spray paint?
I have painted a lot over my years, but never car parts, cause they scare me, truly!
I used Rust-Oleum rattle cans on the frame and undercarriage of my Cadillac over 20 years ago. I use the vehicle as my primary transportation and is still looks like new.
I rattle canned the side cover, engine cover and draft tube on Ol' Roy's engine and the rest of my vehicles. It's durable and lasts a long time. If you can powder coat it, go for it but It's not necessary.
1950 Chevrolet 3100 (Ol' Roy)
Ya, I've never done that but know people who have. It can give a decent result but I wouldn't do it on a restoration project.
Regardless of paint and method used, the single most important factor in achieving beautiful, lasting finish is the preparation. That goes for auto parts, bodywork, houses, furniture, etc.
I painted my house and the finish was smooth as glass and no peeling or flaking after 11 years. I spent a lot of time grinding the 90 years of paint off of it down to the bare wood. Sanded, prepped, cleaned, etc before a single coat of oil based primer went on. Then let that dry for a week before 2 coats of acrylic latex went on. I applied it with a brush, not a paint sprayer.
My point is that you can achieve perfection with whatever method you choose, just make sure the bodywork is perfectly straight, perfectly smooth, and hermetically clean before applying the primer and finish.
Re: Powder coating vs. conventional paint. Powder coating requires heating (as you probably know), so it's a two step process. One disadvantage of powder coating it that if rust gets under it (chip or whatever), it can grow under the coating and it will peel off in sheets. Conventional paint (epoxy primer, filler primer and topcoat) can be repaired more easily than powder coating. Conventional paint system gives you a chance to correct small defects in the surface before you topcoat. I'm not sure that powder coating could even be applied on a part that has a little filler on it. I wouldn't recommend powder coating on body panels. re: Rattle cans Most have less than optimal spray pattern versus an air powered paint gun (even the cheapest Harbor Freight gun) and what happens when the can runs out of propellant 1/2 way thru a panel and you have to go buy another one. And when a rattle can starts to lose pressure, they'll start spitting big globs of paint instead of a nicely atomized spray. Rattle cans are fine for small items I have used them for various parts, like the brackets for my oil filter mounting, the oil filter canister itself and for touch up of spots on the frame, which I sprayed with epoxy primer and Rustoleum Industrial Enamel in quart cans.
I bought a 3M Accuspray paint gun with disposable nozzles and paint cups, which make gun cleanup very easy. A gun and starter kit is available on AMAZON It was just over $200 when I bought mine. It does a good job.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
Simple question: do I need a shop manual for my 1948 GMC rebuild or will my Chev. shop manual 1948-53 do?
The answer is "It depends"
In USA manufactured trucks, the differences are primarily engine and electrical grounding.
Is your GMC a Canadian manufacturered truck? If so, it left the factory with a Chevy engine and I assume (there's that word) a negative ground electrial system. If your GMC was made in the USA, it had a completely different GMC engine and a positive ground electrical system. Most other parts are interchangable.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
I think I get the 'drift' out of what you all have said and it comes into my direction of thought.
The book I will order and see what I can learn from it. Interestingly, I was brought-up by a father who requested the parts book when he ordered a new machine, tractor etc. and I recall one instance when the seller (in does olden-days, the owner of the company) sent the manual. My dad went ballistic and told the good man 'how can I know how the parts in the machine work together if I don't know how they are put together' and that is exactly true. Well, today nobody once you to know how everything works together, cause people without knowledge are easier to herd.
Powder-coating struck me the first time my oldest had everything build for our oven and put charge to a build piece of steel, sand blasted and clean as can be, washed and 'gased-off', stuck the primer powder on & backed it, pulled it out and sprayed the actual color on, backed it again, pulled it out and clear coated it and backed again and after letting it cool the part went into whatever it was made for. No day to wait for it to dry or the scare to touch it to put finger marks on.
But I get your drift (again) and will do it for the frame, because once sandblasted (with low pressure and fine grid sand) the whole frame can be nicely done. Some structural parts we will do ourselves (powder coat) the rest will be sprayed. My son has what Kevin mentioned, a 3M accuspray. Not sure if he let's me use it, I doubt it, but I have seen the advantage of the system, particularly for smaller amounts to be sprayed and will invest in one myself to get this right.
Joerg - I see you've identified your '48 GMC in your signature line as a "Model 9434", a Canadian GM produced truck. For Shop Manuals to support your truck, you'll need both the 1947 Chevrolet and GMC Trucks Maintenance Manual, like this one currently offered on ebay located in Nanoose Bay, British Columbia, Canada. Plus a 1948-50 Chevrolet and GMC Trucks Maintenance Manual Supplement to 1947 Manual offered by Faxon Auto Literature in Riverside California.
The 1947 manual is the basic complete Maintenance Manual. The 1948-50 Supplement to the 1947 Manual covers only changes from the 1947 model year, so not a complete book by itself.
I actually own a set of both of these manuals in my personal "Stovebolt Library", so if you need some help or specific information for your '48 before you can acquire your own books, send me a PM and I'll be glad to try and capture and provide you with pictures of the manual sections you may need.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Both front fenders off, need my helper for the front part to get the bolts out.
No idea why the put 1" or 1 1/2" bolts in where 1/2" or max. 3/4" would be long enough. I guess the builders didn't think much of me having to run 3/4 rusted thread through a nut where one needs specialty wrenches to get in and hold the opposing side of the connection.
My method for removing rusty fasteners is to tighten them till they snap.
The easiest way to remove the front fenders, rather than individually, is to unbolt them from the cab and pull the whole front clip in one piece. But it looks like you got it done.
